Tiller Did anyone ever regret getting the bigger tiller?
   / Did anyone ever regret getting the bigger tiller? #11
I'd say more a matter of how fast you want to get the job done, and how open or tight the quarters are.
I run a 50" tiller behind my little 22HP 455 and scratch my head when people worry about having enough power to run a wider tiller.
Maybe if I added 500# to my tiller to get it to sink better, it may be an issue, but the way it is, I have removed the shoes to let it sink better in our heavy soil, and it still rarely works the engine...
   / Did anyone ever regret getting the bigger tiller? #12
Good point. I do not run out of HP. The problem I have is the tiller starts hopping around if I try to go too deep at first. Not sure if a smaller tiller would help or not.
   / Did anyone ever regret getting the bigger tiller? #13
<font color="red">
Good point. I do not run out of HP. The problem I have is the tiller starts hopping around if I try to go too deep at first. Not sure if a smaller tiller would help or not. </font>
Could be a couple issues there. You travel speed might be too high to let it stay down. It might also be a weight issue with the tiller. Or a combination of both. Mine doesn't hop around once it goes down. I've got hard clay and find that it will bounce a bit as I ease it down but then it digs right in and stays down. Seems that most of the reports I see about bouncing tillers comes from people with gear tractors, I'm not going to get into the gear/hst debate, but some gear tractors don't have a slow enough gear for tilling. But the think I would try if I was you is to slow the ground speed down a bit and see if the tiller still hops around.
   / Did anyone ever regret getting the bigger tiller? #14
I'm with you Bob... I think the hop is probably from ground speed being too high. Like some of the others have said, I am satisfied if my implement (disc, tiller, shredder, etc.) will cover my tracks. I would rather not work my tractor hard 100% of the time. On the ground speed track... any of you guys with 'back in the day' tractor experience... do y'all notice 1st gear seems higher across the board today? I remember those 2 cyl JDs could easily be outwalked in 1st 2nd and most times 3rd. And they only had 6 forward gears.. no Hi/Lo range.
Oh, back to the post... I would only worry about covering my tracks. And the smaller tiller would probably be more versatile by its nature of fitting inot tighter areas. We have a 12'7' disc that is great for large acreage but who wants a 50 acre household garden?
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
2014 Electric Cart (A53424)
2014 Electric Cart...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
