Delrin, tivar,torlon or teflon sheets
   / Delrin, tivar,torlon or teflon sheets #1
gws
Platinum Member
yanmar ym1810
I am looking for a small "hunk" of insulative platic.
I need a block 6" x 18" x 1" could go a little smaller but not much.
Everyplace I have looked wants me to buy large sheets at VERY high prices.
Gary
   / Delrin, tivar,torlon or teflon sheets #2
Gary....could you sandwich 3 or 4 pieces to get the desired thickness? I've got a sheet of quarter inch thick silicone rubber probably 12 inches square and it will sustain pretty high temperatures. It's yours if it will help.
/forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Jon
   / Delrin, tivar,torlon or teflon sheets #3
Where are you located? There is a salvage "yard" in St Louis MO. It is actually indoors. It has odd lots of every kind of metal and plastics.
   / Delrin, tivar,torlon or teflon sheets #4
McMaster-Carr will supply sheets down to 1sqft of most or all those materials you mentioned. For instance, if you can use HDPE, McMaster has 1"x24"x12" stock for about $32. They will also custom cut. http://www.mcmaster.com
   / Delrin, tivar,torlon or teflon sheets #5
Think "cutting board", look on internet for .coms selling these precut or custom cut. All plastic should be insulative. The material available with properties close to Delrin would be nylon.
I have found 3/8" or 1/2" cutting boards in stores usefull for marine and other projects.
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
New Holland B95 Backhoe (A50490)
New Holland B95...
Char-Broil Gas Grill (A50860)
Char-Broil Gas...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
