Flail Mower Del Morino Flipper Hammer Flail Mower
   / Del Morino Flipper Hammer Flail Mower #11
Thank you for the compliment Innrkid, I will continue to try to live up to it.
ransonjd,
You can have either the flail hammers or the side slicer knives.
I would just invest in the side side slicers for now if you are ready to buy and
get used to the flail mower over the summer and fall and then decide it you want
flail hammers for it.
Also keep in mind that with the flail hammers you will have less cutting edge in total
inches per foot of width of cut. The side slicer pairs will have more total cutting edge
length in inches per foot of mower width and you can flip the knives to expose a new
cutting edge.
Using a wet well grinder for maintaining the cutting edge will save you time and money
and will not overheat the knife edge and ruin it.
The MicroMark folks have a wet well grinder for $99.00 and its perfect for flail mower knives and
hammer flail cutting edges.
JUST keep in mind the hammers will not shred the brush/material a second time
and the side slicers will shred the material up a second time as long as the
mower is set up with the mowing height set at 2 inches or lower.
When mowing in good sod you will be able to mow it once but not recut it a
second time.
ideally if you have brush clumps its best to back over them and then drive
forward to shred them up even finer as the rear roller will help you a lot in that situation.
islandtractor has plenty of before and after images showing how well the B flail rotor on his B59 Caroni flail chews up the big brush clumps with immature weed trees he is clearing off the farm that he owns.
Recognizing that leonz has forgotten more than I know.....the manufacturer notes that hammers and knives are NOT interchangeable without a rebalance. It's on their website.
   / Del Morino Flipper Hammer Flail Mower #12
Where are these flails mowers sold in the US?
Cummings and Bricker Is the eastern distributor I called them and arranged sale through Bane-Welker in Indiana. I'm sure there is somebody closer to you and C&B should be able to help.
   / Del Morino Flipper Hammer Flail Mower #14
Anyone have experience with Del Morino flail mowers? I'm considering a flail mower as slightly safer alternative to a bush hog for keeping down grass and chopping up some brush. One local dealer sells the Del Morino Flipper FLI186M, a 74" mower with hammers rated for brush up to 1.5". I've only seen Del Morino mowers mentioned a couple times on the forums.
--John
does anyone have experience with Iron Craft Flail Mowers (is a US-based company that has been manufacturing flail mowers since 2002)?.
   / Del Morino Flipper Hammer Flail Mower #15
   / Del Morino Flipper Hammer Flail Mower #16
Very familiar with Ironcraft in general. They used to be called Titan Implement until an importer used a similar name and damaged their brand. I've got their Pallet Forks.
They also have a ditch flail I've been considering.
Super good info thanks
   / Del Morino Flipper Hammer Flail Mower #17
Thanks. I did not know that
   / Del Morino Flipper Hammer Flail Mower #18
I got a price on a Del Marino Centurion Super flail. It was almost double the Ironcraft pricing. I don't know enough either way, but even assuming the Del Marino is better in every way, it is pretty hard to swallow a 100% price difference.
   / Del Morino Flipper Hammer Flail Mower #19
Hello Torvy,
If you can live with/make good use of a standard flail with no side shift or extended boom
with your mule you should look at a wider Vrisimo flail mower.
   / Del Morino Flipper Hammer Flail Mower #20
Hello Torvy,
I need to do ditches at angles I don't think I want to traverse with the tractor.
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2007 International 4300 (A53314)
2007 International...
KUBOTA M955 DUAL SPEED TRACTOR (A57192)
KUBOTA M955 DUAL...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55852)
2014 Peterbilt 384...
