deisel won't stay running when warm
   / deisel won't stay running when warm #1
dnodolf
my satoh loses power after the engine warms up. just put new rings and injector pump in it. acts like it is under load and shuts down. Any ideas
thanks
   / deisel won't stay running when warm #2
thanks
When you say it acts like its under load does it start putting black smoke out of the exhaust?
Could it be that the fuel filter is partially plugged off?
How about the mechanical fuel pump, is it supplying enough fuel?
Could you be a little more descriptive of how it acts?
Do you have it revved when it starts to power out?
I have seen fuel starvation cause a shutdown like this but more details would help in a diagnosis.:thumbsup:
   / deisel won't stay running when warm #3
Filter sounds likely. Maybe crud in a fuel line?
I once had a piece of debris in a gas tank that was just floating around near the bottom. If I ran the engine flat out for any period of time, the increased suction would draw the debris against the outlet port, blocking it and causing the engine to stumble. It would recover once it was at lower revs and the suction was reduced enough to release the debris. Drove me crazy for months until my fuel gage sending unit started going and the fuel gage would go from 3/4 tank to empty in a heartbeat. Found the debris when I drained the tank and R&R'd the sending unit. Suspect the debris came from the sending unit. Bust out the flashlight and have a look in your tank - maybe a cheap & easy one to fix!
Anvil (A50860)
Anvil (A50860)
Scag Liberty Z Zero Turn Mower (A50860)
Scag Liberty Z...
2017 Ford Escape SUV (A48082)
2017 Ford Escape...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2008 FORD F-450 (A50854)
2008 FORD F-450...
Metal Door (A50860)
Metal Door (A50860)
