deere x495 cooler line problem
   / deere x495 cooler line problem #1
fredbaro
monroeton pa
x495
hello i have deere x495 was cutting and all trans fluid started pumping out.found 1 of the cooler lines came off thought it was going to be easy fix.losend clamp reinstalled line and refilled trans.started and all seemed fine took for a little ride and saw fluid pumping out again and same line popped off. anyone have any idea`s why this would happen was thinking maybe plugged cooler causing to much pressure. thanks for the help
   / deere x495 cooler line problem #2
I think I would connect the Input side of the cooler, and remove the cooler OUT line and place in a bucket and see if there is good flow through the cooler.
If there is good flow through the cooler, then look for a blocked return filter if it has one.
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
Lot of 9 Vehicle Jack Stands (A48083)
Lot of 9 Vehicle...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2020 JLG Telehandler (A49461)
2020 JLG...
