Deere Generator 30 amp
   / Deere Generator 30 amp #11
I disagree.
All mechanically-coupled, direct engine-driven alternator heads produce a true sine wave AC output waveform. In fact, it would be tough to design such a direct driven alternator head to produce anything else. It appears the OP's generator is a mechanically-coupled direct engine driven alternator.
Wrooster
Sine wave in theory. Most small generators produce power with 5-8% harmonic distortion. This is due to the design and materials used. As a result the output is not quite a clean sine wave. Fine for nearly all loads, but not quite a "true" sine wave.
paul
   / Deere Generator 30 amp #12
   / Deere Generator 30 amp #13
Looks like a nice unit, would recommend that you looking into a transfer switch for your main electrical box.
We put one on our 200 amp Square D service box and when we lose power it is a simple push switch that locks out the incoming service and transfers to our generator input. We ran the cable to the back of the house for safe operation of the generator outside!
At the same time we put a lamp on the public service side of the box so we would know it the light is on the power is back.
What we have is a push bar system that installed directly into the panel and requires turning off the main breaker before you can switch to the generator input. This permits using all of the breakers inside the box and ensures no voltage is going out onto the public service side o tthings.
Kit K-5410 for Square D Panels
A few years ago we were out of power for about four days and the last day we ran the generator for nearly four hours before someone called to tell me the service was back up. What we run into living in the country!
Just my two cents.
Wayne
   / Deere Generator 30 amp #14
Wayne thank you for takeing the time to post/reply back. Good info and advise given no doubt but I will be using genny in remote location with a travel trailer.
Boone
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
Metal Door (A50860)
Metal Door (A50860)
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
1985 Ford C-800 Grumman Fire Truck (A50860)
1985 Ford C-800...
