3-Point Hitch Deere 4720 Three Point Hitch Failure
   / Deere 4720 Three Point Hitch Failure #1
TCowner
Platinum Member
SE Minnesota
John Deere 4720 Cab
I was leveling with the box blade this afternoon and the three point hitch failed. The lever in the cab is moving the cable but there is no movement of the rockshaft.
My local dealer is sending someone out tomorrow but I was curious if anyone had some thoughts on what has failed.
   / Deere 4720 Three Point Hitch Failure #2
My "guess" would be a linkage or cable failure. Did the resistance of the lever change at all?
   / Deere 4720 Three Point Hitch Failure #3
I have been told deere used a cable system kinda like the old choke cables and they are prone to failure. This system is only used on the cab models and deere is supposed to be upgrading on the newer cabs this year. Good Luck
   / Deere 4720 Three Point Hitch Failure #4
This year as in 2008, or 2009?
UPDATE: It sounds like bad news. The dealer sent a tech to look at it today. He believes its not a cable problem but an internal one. He said he would have to open up the rockshaft housing. It should be a warranty issue but it is still a concern. I have less than 100 hours on the tractor and this is the second issue for me. THe front windshield wiper had to be replaced during the first month. I hope this isn't a sign of more of things to come.
The tractor will be picked up tomorrow and they thought they should be able to get at it right away so I should know by tomorrow afternoon what happened. I will update as soon as I know.
   / Deere 4720 Three Point Hitch Failure #6
Man, that sucks.
What was wrong with the wiper?
Does the windshield washer spray the whole windshield? The one on my new 4520 only spray the lower part - kinda sucks.
D.
It was a windshield wiper motor failure. It was replaced under warranty but it had been used probably ten minutes at most before it failed.
   / Deere 4720 Three Point Hitch Failure #8
The wiper spray pattern can be changed. If you look at where the washer fluid is squirted out you can see they are little balls that can be rotated around. I used a small screw driver to adjust two of them. It now has a nice even distribution of washer fluid. Hope it helps.
   / Deere 4720 Three Point Hitch Failure #9
Many thanks for the info about adjusting the washer fluid spray. Can't wait until tomorrow to fix mine. Always thought it had dirt or something.
That is one of the great benefits of using this forum.
   / Deere 4720 Three Point Hitch Failure #10
OK, I will go check it out.
Thanks,
D.
UNUSED RAYTREE RMA42' HYD AUGER (A57193)
UNUSED RAYTREE...
BOMAG BW75AD WALK BEHIND SMOOTH DBL DRUM ROLLER (A52707)
BOMAG BW75AD WALK...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
2017 JOHN DEERE 333G SKID STEER (A52707)
2017 JOHN DEERE...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A57193)
UNUSED SDLANCH...
2017 FREIGHTLINER CASCADIA SLEEPER (A57880)
2017 FREIGHTLINER...
