Dealer recommended no ballast in tires
   / Dealer recommended no ballast in tires #31
<font color="blue"> I have heard good things about filling them with foam. Once you do though you have to cut them from the rims if you change your mind.
</font>
I'm going to foam fill my next set of tires. I'm a big fan of loaded tires (can you tell /forums/images/graemlins/smile.gif), but foam is expensive. My tires are worn enough that they'll need to be replaced before much longer so I'm putting off the expense until I can get as much "milage" out of 'em as possible.
Sure, no changing your mind. But no flats either! /forums/images/graemlins/grin.gif
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
ATTENTION PLEASE READ (A57148)
ATTENTION PLEASE...
2013 MACK CHU613 BOBTAIL VACUUM TRUCK (A58214)
2013 MACK CHU613...
LOT: (8) Wheel Loader Bucket Teeth (A59076)
LOT: (8) Wheel...
New/Unused CFG Industrial MH12R Mini Excavator (A57453)
New/Unused CFG...
New/Unused AGT Industrial Quick Attach Auger with 3 Bits (A57454)
New/Unused AGT...
