Daytime running lights
   / Daytime running lights #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I just got a new truck and was disappointed to find that it didnt come with DRL.. I found some LED lights that ppl use for DRL and then i went looking for a wiring harness..
I found some a wiring harness on ebay/internet that will turn on added DRL on when the engine running, BUT it got a few bad reviews.. And in VA we have to have our vehicle state inspected annually, and didnt want to run into issues with with how the DRL were wired at that time..
Can someone tell me when DRL are suppose to be on (ie when the car is on or when the car is not in Park), and are the parking lights suppose to be on with the DRL..
Any suggestions on where to hardwire added lights so they work just like they do from the factory?
thanks
b
   / Daytime running lights #2
What kind of truck did you get?
I know on my Silverado, the DRLs are only on when the vehicle is in drive and it's daytime (enough ambient light to shut the headlights off.)
The parking lights will not be on when the DRLs are on since you will be in drive.
Cliff
   / Daytime running lights #3
My DRL are always on (unless reg lights on at night or parking brake is applied)
   / Daytime running lights #4
My 2001 Blazer has stock GM DRL's and they are only on when not in PARK. I added a kit on my 2002 Dodge Cummins truck from J.C. Whitney that lights up my fog lights. The DRL's apply about 70% of normal voltage to the lights, plus or minus. Parking lights on during the day is not good, and I ***** constantly about the folks who rant to people to turn their normal headlights on during the day in bright sunlight driving on the Xways. It helps the people see you from the front, but muddles the difference between your brake lights being on or off to the people behind you. This was especially bad with the older Ford vehicles that had plastic lens that turned milky after getting old. The DRL thing came up years ago when people had to drive and pass on two lane roads, and there were lot's on head on accidents. Not needed as much on the Xways, but over all a good thing. I think DRL is mandated by law up in Canada... ")
Cliff
I got a Nissan Xterra, had a 02 Dodge Quad Cab Ram/cummins 3/4 ton 4x4..
thanks for explaining how your lights work
b
   / Daytime running lights #6
Seems to me they are just a wast of money and just something else that can go wrong. The way I see it, if someone can't see a truck coming down the road I really think a couple of lights won't make much difference. It's not like you are driving a motorcycle which can easily be overlooked. just my 2 cents.
   / Daytime running lights #7
DRL's have been law up here since hmm 1988 or so? They work great, let you see vehicles much easier in all conditions. Its pretty noticeable when a non drl US vehicle is driving the other way as they have to be about 50% closer before you notice them.
I wish motorbike's all had, them, those suckers are hard to see in busy city traffic on a greyish day.
   / Daytime running lights #8
As a former pro truck driver, what I like about DRL's is that they reduce the number of vehicles driven by morons too lazy to turn on their lights in poor visibility. It's not just about being able to see so you can drive, but being VISIBLE to other drivers. Back about 1986 I was driving a work truck and came to a stop sign, looking very carefully into the dusk both ways I saw nothing, but as I began pulling out to cross the road I saw a shimmer of light on the side of a car about 300 feet away coming toward me, a car parked in a driveway had it's backup lights reflecting onto the road and caused the shimmer. If not for that it's likely the lightless car would have hit my truck broadside and I would have been at fault for failure to yield. I am sure many of you can relate the same type of story.
   / Daytime running lights #9
Do you drive much in the morning or evening? That is when I see the biggest advantage for the DRLs. If you are looking into the sun, cars can easily blend in with the road. Those little specs of light make it much easier to see a vehicle coming at you from the direction the sun is shining. I'm not for any more regulations on what cars have to have and all that good stuff, but I do think DRLs are something that should be required. It adds very little - if any weight and costs very little, but the benefits are big.
   / Daytime running lights #10
Agree 100%....and it will show you just how old I am when I mention that back about 1965 or so mail order auto parts and accessory catalog firms like JC Whitney were offering an add-on white front light to install on the front end of cars that were a very early version of DRL's. I recall seeing them on cars while being bused to school back then. Not sure what they were called then, though.
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
WACKER NEUSON PD3 TRASH PUMP (A58374)
WACKER NEUSON PD3...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2024 INDUSTRIAL  MINI EXCAVATOR (A58214)
2024 INDUSTRIAL...
2022 Magni TH5 5.19P (A56435)
2022 Magni TH5...
2022 International MV607 Terex XTPRO56 56ft. Insulated Forestry Chipper Bucket Truck (A55973)
2022 International...
