Danger for young eyes?
   / Danger for young eyes? #11
+1 on Yomax: Why would anyone think that a manufacturer would have a setting to adjust the time it takes to darken (DUH) on a welding lens. I see the main thing to look for in welding helmets is the fit of the lens in the helmet so that there is no light leaks from the perimeter and of course the comfort of the fit. The AD lenses all seem to work well with regard to protection. A lot of folks on these forums like to brag about what they paid for their helmets so they think they are getting better eye protection while all they are really getting is less money in their bank account. I am not saying that some of the helmets arent more comfortable or better made than others, but for most home uses, a HF (or other brands of equal price)AutoDarkening helmet is sufficient and you dont need to spend $300 on a helmet that you only use a few hours at a time at most. Jackson and Hobart used to make great hoods, but lately, I cant see much difference in them and any Chinese or Korean made one and very likely most of them are made in the same countries.
PS: I can tell you that excessively sweating onto the HF lens will ruin it as it is for sure not waterproof. I have had to throw one away due to that problem
   / Danger for young eyes? #12
Look for approval ratings from UL or ANSI. If approved. It has been tested. I think there is only 1 AD manufacturer in the US and that is Jackson ?. The rest of the 50 or more come from Korea, China, Taiwan or the Swiss. Also, Those countries are eons ahead of us in electronic technology just as Europe is eons ahead of us in Welder technology.
Seems welding helmets are rated as meeting the ANSI Z87.1 standard. Unfortunately, the standard doesn't mention auto-darkening of the lenses unless I'm missing something.
I wonder if there are standards that cover auto-darkening requirements.
http://www.safetyeyeglass.com/ansiz8712003.html
   / Danger for young eyes? #13
Nothing could be more untrue. They may manufacture more than we do but they get the theory from this country. Microprocessors, lasers, audio, communications, satellite, wireless, you name it, most of it was invented in the U.S. with a few exceptions and then copied by Asian countries. The most complex, mass-produced product ever manufactured by mankind is the large microprocessor and that is an Intel invention and they still lead the markets by a long shot.
   / Danger for young eyes? #14
I would als like to know if there are standards that cover auto-darkening requirements
   / Danger for young eyes? #15
ANSI Z87.1 is an impact resistance standard for safety eye wear and face shields. It has nothing to do with the autodarkening aspects of the helmet or protection from arc flash. I'm not aware of the standard for welding arc protection.
   / Danger for young eyes? #16
How about this one?
   / Danger for young eyes? #17
ANSI still comes into play because there are several manufacturers that use lexan or another resin type material. Sellstrom sells a lens from Sweden that is water proof but may melt in the sun. The other can crack just by squeezing it. As far a regulatory agency that tests AD filters, I am looking for one too.
   / Danger for young eyes? #18
What people don't seem to understand is that in most all cases, Your eyes are protected to an equivelant of shade 16 even in the light state before your lens turns dark. That don't mean you want to keep welding in the light state it only means you are protected as far as UV and IR are concerned.That makes switching time not that important. It's done with UV and IR Filters. Delay only keeps the shade in the dark state a second longer so you don't have to look at the white hot puddle after the weld. Sensitivity is more for "Tig" than Mig or Stick. It makes the lens Stay dark instead of flickering while welding.
So many posts on here are people thinking that Delay keeps the lens from Darkening and that is not the case. It keeps the lens from lightening after the weld. :confused2:
yep.. that's what the manual on my 35$ auto dark / chinese helmet states. full uv protection even if the bat is dead.. it's built in to the lense.
I usually set mine outside on the mornign before I weld to make sure it has some charge built up.
I've never had an arc burn or been flashed with that helmet. have been flashed many times with an old flip down fixed shade.
have seen a few arcs that i though maybee didn't darken fast enough.. or whatever.. but notheing that hurt or made me blink.. and no spots when looking in a dark corner.. and no sand inteh eyes.
I also wear a high collar weld jacket to prevent reflection flash under the helmet...of course.. now the 'beard' helps with that more and more.. :)
i've only used my flip down helmet once in the last 2-3 ys since I got the auto.
I tend to runthe auto on about 11... once kicked it to 12 or 13 with my glove and thought I was going blind.. couldn't see the puddle.. :)
soundguy
   / Danger for young eyes? #19
Yomax - Not sure what you are saying there...I wasn't implying Z87.1 wasn't applicable, as it is - but for impact protection, not for welding arc protection. Z87.1 eyewear is required for use when welding for impact protection by OSHA standards. But Z87 says nothing about welding arcs to my knowledge.
Thanks for all the feedback. I have used my HF auto darkening helmet for at least three years and love it. Now we are a three helmet family. When you are as uncoordinated as I am being able to see the stick helps a lot to strike the arc. I know I will never make good welders out of them but at least they will be introduced to welding and if they would like to pursue it then we can get them into some classes.
:)Thanks again.:)
A.Metcalf
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
250ft Roll of Copper-Clad Aluminum Building Wire (A55852)
250ft Roll of...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
