Danforth type anchor for 19.8 Carolina skiff..
   / Danforth type anchor for 19.8 Carolina skiff.. #1
MF243RedTop
Statesboro, Georgia
Massey Ferguson 243
Wasn't impressed by what was available online or in stores .. so collected scrap and proceeded to build this.. 16" wide by 22" long
Flukes from galvanized Angle and anchor pivot 3/16" ..
Used a 1/2" rebar ground down for rod.
And 1.5" by .5" thick adjustable handle from an old plow for the shank.
Haven't weighed it yet but probably 10-15lbs..
Coat of primer on mild steel and bedliner . sanded and etched galvanized and just coated with bedliner ..
   / Danforth type anchor for 19.8 Carolina skiff.. #2
Nice ! Many boaters don't know this, but on our Great Lakes, having many rocky areas, we tie the end of the line ('rope') at the base of the anchor teeth, and then use a weaker line to attach it on top root. If the anchor gets stuck in rocks usually because of high waves, when you pull VERY hard or the boat wants to go windward, the top rope breaks and the anchor head is easily freed.
Yeah I have a hole drilled in it for that .. if look at the side view you'll see it... Don't plan on losing this one anytime soon.. mostly will be used in the intercoastal waterway and beaches of Georgia
   / Danforth type anchor for 19.8 Carolina skiff.. #4
Depending on the size and windage of you boat and the wave action, 10 - 15 pounds won't hold much. You might want to add 6 to 10 pounds of chain between the anchor rode and you anchor.
1998 POLAR TANK (A58214)
1998 POLAR TANK...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
2013 Felling Trailers 8 Ton T/A Side Dump Flatbed Trailer (A56858)
2013 Felling...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
