CUT Hour meter broken - what to do?
   / CUT Hour meter broken - what to do? #11
My 4400 fuel gauge will spin all the way around and get stuck sometimes. Now I can have the cluster out and back in about 30 minutes, about 5 minutes of that is windexing the glass for dirt and fingerprints. I'd assume yours is similar effort to get out but not sure if it is glued together on the back side.
Hmmm Does yours have tilt steering wheel? Seems like that is the gotcha on mine.
   / CUT Hour meter broken - what to do? #13
Yes I tilt the steering wheel down to pull the dash up which is held on with the 4 Phillips head screws that are easy to get to. Then there's about 8-10 small Phillips head screws that attach the cluster to the dash from the inside. If I remember correctly once those screws are out the glass can come out, so be careful it doesn't fall out on you.
   / CUT Hour meter broken - what to do? #14
This is what my dash looks like when it's apart. I was testing the fuel gauge here, it was stuck when I bought the tractor.
Thanks! That is a huge help.
My fuel gauge never has actually worked. Thank heavens for auto bleed injectors!
   / CUT Hour meter broken - what to do? #17
rocky
Good to see you found a replacement for the hour meter. And that it was an easy install/fix. Would you have the source with part no. for that hour meter? Was a fast fix.
I put the link in the other thread.
I actually ordered a complete hour meter assembly that almost certainly has the same components. It cost a bit more but I'll have it Monday.
Still a LOT cheaper.
It isn't over yet, but I really appreciate all the help. If it weren't for the suggestions - I might not have figured it out.
Especially Texasranger556.
The irony, of course, is that I studied electronics once apon a time. I really have no excuse for not seeing the solution instantly.
Oh well!
   / CUT Hour meter broken - what to do? #20
Oh well!
Glad to help. Now I'll know what to do if mine stops working!
Nice work!
Horse Statue (A55853)
UNUSED (2) 3500# AXLES W/ BRAKES (A57192)
UNUSED (2) 3500#...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
UNUSED FUTURE 29" PALLET FORKS W/ MAST (A57193)
UNUSED FUTURE 29"...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
UNUSED PABREAK METAL BEAR SHOOTING TARGET (A57193)
UNUSED PABREAK...
