Cut a hole in my house on purpose
   / Cut a hole in my house on purpose #11
I’m not sure how much wood I burn, less than a cord of wood a year. Roughly every 5 years I clean mine. I get enough crap out to fill a gallon milk jug usually. Definitely clean your flue.
   / Cut a hole in my house on purpose #12
I burn about 2-3 cords of wood each season. Chimney is insulated 6 inch SS liner in 8 inch square tile. About 16 feet long. Here's three years of ash swept down. Not a lot of creosote, mostly ash in pipe. It does restrict flow
   / Cut a hole in my house on purpose #13
I believe I'd have taken out another stud (doesn't appear to be load bearing there) and put in either a door or window. It may be deceiving, but that attic space almost looks big enough for a small room and a window might be quite fitting.
How far out from there is the chimney? Is it along that same roof peak? If so, is it possible to do a catwalk type of thing from there to the chimney?
I probably would have done the same. Even if the space isn't suitable for a room, having natural light in an attic would be nice.
Catwalk sounds like a good idea if the chimney is accessible from that section of roof. Would also give a bit safer place to stand.
To the OP: how accessible is the bottom of the chimney for cleaning? From the picture it looks like stainless steel, might be easier to clean from the bottom, that's what I do though my chimney is external to the house and any creosote/soot that doesn't get caught just goes on the grass. Might be different if it ends in the living room. :cry:
My wife will also smolder a fire instead of burning clean....grr.
Yeah, mine too.
   / Cut a hole in my house on purpose #14
Thanks. Mine is probably 12 feet long. I figured that when winter hits, we burn it so hot that it would burn out anything on the pipe, but since I never looked, or tried to clean it, I really don't know what's in there.
Breyer check and be safe instead of sorry. When I was heating exclusively with wood, I would clean the chimney twice during the season.
   / Cut a hole in my house on purpose #15
For fall protection, I wouldn't worry about in much as long as as you keep the tether snug. Not much momentum build up that way.
At work we had a demonstration where 1/2-5/8"rope was over an A-frame structure and a 225# sand bad weight was dropped 6'. The rope snapped immediately.
   / Cut a hole in my house on purpose #16
Your setup to get on the roof is way too similar to how I did a swan dive many years ago. The ladder was straddling the peak of the lower roof, I had one leg on the upper roof and the other on a rung when the ladder kicked out. I must have used 8 of my 9 lives up when I hit the ground... I got up and said “*.*”, I’m ALIVE!!!!!
I’m glad to see you utilizing safety equipment. 👍
   / Cut a hole in my house on purpose #17
So lucky chimneys are not needed here. Only older homes that had wood stoves may still have them but most are blocked off now.
As a kid in New Zealand we used to have chimney fires now and again. The roar was quite frightening. Dad would soak a wheat sack and climb up and smother the top of the chimney with it.
   / Cut a hole in my house on purpose #18
The one time that I had a chimney fire I opened the fire box, touched a fire extinguisher off and put the fire out instantly. The scary part is if you don't have a good chimney, that's when it can spread to the structure.
   / Cut a hole in my house on purpose #19
I heat with wood. I have a wood fired indoor boiler and radiant floors. I was having my triple wall chimney swept every year. The access was precarious. I got fed up with chimney sweeps. I had to call every year to get set up. I never understood why they weren't calling me since they knew I wanted it swept every year.
The final straw was the sweeps free chimney inspection. He pointed out some problems which I could clearly see also. But, he didn't replace chimneys, and couldn't provide any recommendations. So great, you point out an issue and then walk away without solutions.
I replaced the chimney myself. But since the chimney path was in the corner of my garage, I added a TEE. Now I can uncap the tee and sweep up and down without ever going on the roof. Flexible fiberglass rods are great. I have a very good view of the cap from my loft (but precarious access) so I can see there is no build up.
Doug in SW IA
   / Cut a hole in my house on purpose #20
Doug in SW IA
I used to climb 2 ladders to get to the chimney then a number of years ago, realized it was a lot easier to pull the elbow off at the furnace and sweep from the bottom. Dohhh:D
2021 John Deere 9570R Articulated 4WD Tractor (A50657)
2021 John Deere...
2010 Cadillac CTS Performance Sedan (A48082)
2010 Cadillac CTS...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
UNUSED 2-Ton Lever Block (A50860)
UNUSED 2-Ton Lever...
2008 Ford F-250 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
2001 International 3800 4X2 School Bus (A50860)
2001 International...
