Curing Hay
   / Curing Hay #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
I'm scrapping out a bunch of bales of Sorghum-Sudan hay I baled in the May-June time line here in N. Tx.. It appears that once again, I didn't get it dry enough and it developed some mold. I realize that SS doesn't pack as tight as grass but it does have to sit out; do not have adequate covered storage and all. This mold is down inside, well beyond of any precip after rolling. I do have and use a crimper and tedder. Don't have a moisture tester. Usually dodging rain. Dry windows usually aren't long enough.
On curing, you guys in Northern climates where your winters are longer and wetter (usually with snow and all), how do you get your hay crops cured out if you run cool season grasses and harvest in the spring.
Thanks,
Mark
   / Curing Hay #2
Thanks,
Mark
We had a moisture tester but I would hardly ever use it. Hard to explain but when I was checking to see if it was ready to roll, I'd get a handful of it off the bottom of the windrow and break it in half. The way it felt told me if it was ready or not. Hard to articulate it with words on the internet but you know what dry dry is. That works but isn't what we wanted. It had just a hair of softness but still broke. Don't know if that's helping or not.
We also took an old peanut picker we got at auction to fluff a raked windrow if it got caught in some rain.
Brett
   / Curing Hay
My rule was grasp a wad in both hands pressed together, palms down and make 3 twists, like pedaling a bicycle. If it snaps on the 3rd loop you're good to go. However very subjective due to curing medium and product.
   / Curing Hay #4
We baled about 100 round bales of sudan grass / sorghum up here we knew it would not get dry, we baled it as silage bales and then plastic wrapped them so it will cook up like silage
and keep. Around here if you do dry bales and don't store them under cover you will lose 30 to 50% because the ground gets so wet and all the rain.
   / Curing Hay #5
All depends on where you are at. Northern states where the climate is dryer it is fairly easy to get hay to cure because the ground is dry and it isn't absorbing moisture from the ground and the ground actually helps take moisture out of the hay. Keeping it dry is no big deal since once again the ground is dry and it doesn't pull moisture out into the hay and when snow comes it freezes and doesn't melt and soak in.
Here in Indiana it is a little different because the ground is damp consequently it is all crimped when it is cut and spread wide - not in a windrow. then quite often it is tedded on the 2nd or 3rd day to get it up off the ground again and fluff it. Finally it is raked right before baling. Soft core bales help some too. The bigger problem is keeping it dry in this climate especially this time of year when it sprinkles almost every day and doesn't really dry then when you get snow that melts it is worse. Consequently most guys store their bales under cover although quite often with open ends for air movement.
   / Curing Hay #6
In central Maine it is cut the afternoon before, rake and tedder, bale the following afternoon . Often there is a morning dew and the sun needs to get to it. The hay should be fluffy before it is is bailed. - I've found if hay is stored on anything but wood flooring, it tends to mold in that first layer - soaking up ground moisture. Bales feel light and flex when dry. Square firm bales that feel heavy usually have some moisture. I stick my hand between the leaves and can tell.
   / Curing Hay #7
Try to sell it on Craigslist as goat hay. At least get something out of it.
   / Curing Hay #8
Next to corn,Sorghum-Sudan is my last choice as forage or hay. It can work and produce's tonnage but unless carfully managed,it can be more trouble than it's worth. We put a lot of small square bales in dry storage before round bales became the norm. Even when stored dry, cattle did poorly. Some have fair results with green silage but we have never tried that. In time's of shortage,I'd rather take a share for baling someone else's pasture grass than raise Sudan and keep it all. Although less than Johnson grass,grazing,Surghum-Sudan risk's prussic acid poisioning at the very time it's needed most.
   / Curing Hay #9
its too easy to test moisture with a microwave and a scale.
   / Curing Hay #10
Please tell me the procedure - I cannot think of how to be accurate. The scale tells you how much you evaporated out but how do you know how much moisture is left in?
2018 Ford F-150 (A51039)
2018 Ford F-150...
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
2002 International 4400 SBA 4x2 (A49461)
2002 International...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
International 4700 Vibra Tiller (A51039)
International 4700...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
