Cub Cadet, GT 1554 “Rat Rod”
   / Cub Cadet, GT 1554 “Rat Rod” #1
thankyouTBN
Kubota B2150, Cub Cadet GT3100
I got a crappy old GT 1550 for that. I’ve been patching together for years. Every time I use it, it breaks. The throttle lever fell off and I honestly couldn’t figure out quick and easy way to reattach it, so I went with the incredibly complicated way. I had to remove the “dashboard” to get out the throttle lever from behind. For some reason I need to takeoff yellow stamped sheet metal fenders. Once I got it apart like that I thought OK no I’m gonna do what I’ve been wanting to do is to move the seat back 6 inches and lower it to inches and put on a bigger steering wheel because it’ll look cool, and also because I’m hoping I’ll have more leverage to turn the steering wheel, hopefully with a steering wheel spinner when I’m backing a trailer into my garage.
So I’m making a whole lawnmower into a “rat rod”. It’s a disaster because it’s taking SO LONG. But I think it’s gonna be bad ass (funny).
The steering wheel wouldn’t fit in my drill press, so I had to use a handheld drill, I was hoping I could get away with using a spiral drill bit to drill out that hole, but there was a keyway in the hole in the steering wheel, and when I tried to drill at the drill was drifting towards that keyway. I had purchased a step drill, and I never used it once. I hoped I could get the step drill to concentric hole that I could then put a holesaw into. It worked. It’s a butcher job, but it doesn’t matter because I don’t need .10000 ths tolerances for steering wheel. I’m totally panicking because this is taking so long but also it’s pretty fun to overcome these challenges. I absolutely do not want to take it into a machine shop.
****! how do I post a video?
   / Cub Cadet, GT 1554 “Rat Rod” #3
You have to post it someplace like you-tube and then paste a link here >
Google is your friend >
2021 Nissan Versa SV Sedan (A48082)
2021 Nissan Versa...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
2017 Chevrolet Colorado Ext. Cab Pickup Truck (A48081)
2017 Chevrolet...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
