Cub Cadet 3206 too Slow
   / Cub Cadet 3206 too Slow #1
GTSRider
Cub Cadet 3000
I have a 3206 Cub Cadet, which I am happy with, with the exception of it being too slow.
I guesstimate about 3mph..... getting this figure from my 2017 Craftsman (MTD) , Rated at 5MPH.
Transmission filter and Cub Cadet fluid has been done, but still painfully slow.
Is there an adjustment on the 3000 series to make them faster moving ?
Thanks,
Pete
Hudson Valley , NY
   / Cub Cadet 3206 too Slow #2
The pedal adjustment is a balance between forward and reverse speeds. The faster you adjust it for reverse speed the slower the forward speed will be. I had a 2004 3235 which I adjusted for the minimum tolerable reverse speed to get the maximum forward speed. When it still seemed too slow I made a modification to allow further forward pedal travel which helped. If you search for my posts a few years ago you will find a description and photos.
Bob B.
Bob B.
Thanks Bob....I will try what you said.
Thanks,
Pete
   / Cub Cadet 3206 too Slow #4
Try reaching down and pulling up on your reverse pedal. If you experience a sizeable amount of speed in reverse, then yes-you need to adjust the balance for the forward and reverse take-up. If its slow, too. Check if you have and play in the linkage or bushings underneath. I have a 3205, myself.
20 ft. Shipping Container (A50860)
20 ft. Shipping...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
71053 (A49346)
71053 (A49346)
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2025 K1119 UNUSED Metal Carport (A50860)
2025 K1119 UNUSED...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
