Cub Cadet 2166 , starts and stalls
   / Cub Cadet 2166 , starts and stalls #1
RJSSR
Cleveland ,OH
Cub Cadet 2166
I have seen this question here before, but the answers did not help me. I think the problem is in the ignition circuit. It will start and run , then die as soon as the key is not in start position. I am not getting voltage to the shut off solenoid, so I ran a connection to the battery (temp) for a test. Spark is good when cranking but will die as soon as key is just on, not cranking. I disconnected the ignition module ground wire ,but it does not start at all. What is killing the ignition?
   / Cub Cadet 2166 , starts and stalls #2
you sure its not in the key switch itself, like a sticking tumbler? try to lube inside key switch
2024 Dodge Durango SXT AWD SUV (A48082)
2024 Dodge Durango...
Poly Tote Tank on Cart (A50860)
Poly Tote Tank on...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2003 Chevrolet Silverado 2500HD Pickup Truck (A50860)
2003 Chevrolet...
2017 Ram 4500 Bucket Truck (A51039)
2017 Ram 4500...
