Cub 5252 blowing fuse
   / Cub 5252 blowing fuse #1
Cub5k
Maryland
Cub 5252
My 5252's mower deck just stopped in the middle of cutting. I checked the fuses and found the middle 3amp fuse blown. I replaced the fuse and started the tractor. The fuse blew within 10 seconds and I didn't even engage the blades. I could tell it blew because the dash diplay went blank. I disconnected the dash, restarted and it blew another fuse. I pulled the pto relay, restarted and it blew a fuse. I can't find any obvious shorts. I have eliminated the dash and the pto relay as the problem. Is there anything else that could cause the middle 3amp fuse to blow other than a short?
   / Cub 5252 blowing fuse #2
KEEP looking you have a wire that is bare and grounding out! check the spots where there might be a pinched wire from engine shroud! keep looking I know it's a pain ,but one of your wire's is touching the frame or somthing eles. I just got done doing this my-self on a 2185 >Mine was a safty switch chewed up by the streeing gear.
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
John Deere Z994R (A56469)
John Deere Z994R...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2019 International Bucket Truck (A55973)
2019 International...
