CobyRupert
Super Member
How about it-anyone have any experience with those logs you put in your fireplace..."
Had the flue professionally cleaned by same guy I have used for years.. Also, the stove is 7 years old and this fall I replaced all the gaskets in it. What a difference-I am probably burning half the wood I did last season.
HOWEVER- I've been burning for about 3 weeks and Sat night before I went to bed I opened up damper, and air control to get a "high burn" to clear out any creosote. Well I went outside to check smoke and had about an 18" flame coming from chimney. Immediately closed down air supply and it dyed down. Usually you can expect a creosote buildup by end of season but after 3 weeks?? And I'm burning good seasoned oak!
Appreciate any opinions
Can't comment on the those creosote-b-gone logs as I've never used them. I sweep my chimney about three times a season. Once before start of season, once during season (Jan/Feb), and once in late winter/early spring when one tends to (barely) burn cold/oxygen starved fires or smoldering fires you keep going during the day just so you have some embers at night. Or if I notice a change in the normal amount of draft, I know I better clean SOON!
How would getting the chimney cleaned or replacing gaskets reduce your wood consumption by 1/2?
Sounds like you definitely had a "high burn". Getting a chimney fire like that after only 3 weeks of burning seems like a short amount of time for dry wood, especially so if your doing regular "hot burns". Like been said, maybe our sweep didn't clean top section.
Do you have a cap on chimney? I don't (but should). I think this leads to a cooler chimney (more creosote), especially when it rains/snows.
Does anyone know if a regular hot fire (but not so hot the creosote ignites) will "dry" the creosote so that it naturally flakes off?
Or what's is the chemical in those special logs?
