Crane attachment for 3pt
   / Crane attachment for 3pt #2
Cool product. Too bad it won't fit my BX, but I did see the compact tractor version with assist wheels. Looks like it would work with something not much bigger than a BX.
   / Crane attachment for 3pt #3
Great in theory (for the compacts)...but I dunno how the toplink would hold up in the long run...the toplink on a CAT I 3pt wasnt designed for such loads...figure that much weight that far out...most of the forces due to leverage are on that poor little single toplink....Its obvious they arent as strong...think...the lift links utilize two 7/8" Pins... the toplink uses a single 3/4" pin....
Then that brings us to the question...are the Toplink mounts/castings on the tractor even strong enough for that kind of stress?
   / Crane attachment for 3pt #4
it is hard to tell from the pictures, but it almost appears it may use it's own version of toplink, one that may/should be much heavier duty than what I/we use for normal 3pt attachments. in the pictures though you can't see it really it appears that whatever is connecting it is very short.
   / Crane attachment for 3pt #5
Very Cool!!
KC
   / Crane attachment for 3pt #7
Interesting. To bad the boom can't swing side to side, like a swing boom log skidder. Or some sort of side shift mabe. Wouldn't have to reposition tractor so much or every time. Lining up with objects or something like putting an engine in a frame would seem to me anyway, more easy. Nifty set-up any way.:D
   / Crane attachment for 3pt #8
That is way cool. Especially the scene where the 8- series John Deere has TWO round bails hanging ten feet off the back end.....
I only put that link on here in case someone wanted to build one. Seems to be made for a very large tractor. A smaller/medium version could be made to suit the limits of your tractor. My B-9200 will only lift abut 450 lbs at the 3pt.
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
