Craftsman model:247.25002 rear motor
   / Craftsman model:247.25002 rear motor #1
rtd2965
kirkland,az
Craftsman 247.25002
I changed all 3 spindles,blades and belt i'm still hearing a noise coming from the right side of the under side of the deck?What might it be?
   / Craftsman model:247.25002 rear motor #2
what type of noise?
what type of noise?
I am on my way to my job I will run it when I get home and listen closely.I'll post later today.
Thank you
Strange, my mower did not make any noise tonight.Maybe I ran over something like a branch or something yesterday..I had the deck replaced last year by Sears it was still under warranty so it was free otherwise the charges would have been over $1200.This year I bought replacement parts on Amazon.The deck was in ok condition so I did not replace it.I also put heavy duty rings on the top and underneath the deck to keep the vibration from tearing the deck apart like a worn out spindle did last year.I only have 60 hours on this mower.
Well after I posted on here last night I mowed some and after about an hour the loud clanging metal to metal sound started when I engaged the deck.idling with the deck up the sound stopped.You think maybe it's the idler/v belt pulley?I checked the blades non seemed bent.Like I said before a replaced the 3 spindles 3 blades and the V-belt.This mower deck has been a problem for 2 seasons.I purchased it in 2013 brand new from Sears.They made these decks cheaply.The rest of this mower is great.
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2003 Acura Tl Sedan (A51694)
2003 Acura Tl...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
