powerscol
Veteran Member
Can someone please check my logic. I am going to be using 1/2 JIC fittings on some of my 1/2 in hose connection. Some of these will be the 1/2 in female ends that appear to measure 1" across the flat. It appears I will be putting them on after the hose are made. So I think I should get the 1.22" diameter product as I think the 1.05" diameter will be to tight to slide on, or does this stuff stretch a bit? Going to use the DHH nylon product, unless there is a better one.
There is a chance I can get this stuff put on when I get the hoses made but not sure. If I can should I got the the 1.05" for my 1/2 inch hoses? I don't think my Bobcat shop carries any sleeve material.
Thanks for the help
Thanks for the help
