Construction of Laminated posts for Pole Barn
   / Construction of Laminated posts for Pole Barn #51
I was also wondering about the laminated posts I am putting up a 60 x 120 Fabric building and the posts that it sits on are to be atleast a 10 x 10 so I am going to make them, I have been told that if you bought a wolmanized post that big that it wouldn't have much treating in the middle anyways.
So I am going to join 2 x 10's and make my own. But I was wondering the best way to go about that. I am only going up 6 ft out of the ground and atleast 4 in the ground so 10' long I think.
   / Construction of Laminated posts for Pole Barn #52
Welcome to the forum! You may want to start a new tread given this one has not been active since 03.
You have to offer more information than what you have. You are going to put 10', 10x10 posts, 4' in the ground and have 6' exposed above ground, right? So you are going to set what on the posts and how do you deal with that hinge point to meet wind loads for your area with that large of structure?
Or, are you setting trusses on top of the 6' posts and having a really low ceiling? (humor intended)
MarkV
   / Construction of Laminated posts for Pole Barn #53
Several years ago I made a gate for my Japanese garden using laminated posts (one 4x4 PT center post with four 2x4 redwood pieces glued to the faces of the center post).
DSCF0104 (Small).JPGDSCF0116 (Small).JPGDSCF0123 (Small).JPGDSCF0124 (Small).JPGDSCF0163 (Small).JPG
Used Titebond exterior grade wood glue.
Hope this helps
Good luck
   / Construction of Laminated posts for Pole Barn #54
This is kinda funny/ironic.
Over the weekend I was searching the Internet for information on Glulams suppliers as well as making your own....
The search found this thread on TBN. :thumbsup::D:D:D Which I read even though the discussion was rather old. Nice trip down memory land seeing some of the old members who no longer visit TBN. :) The information was still good. :thumbsup::)
Then this thread pops up alive again. :D
Later,
Dan
   / Construction of Laminated posts for Pole Barn #55
You also need to consider that it will take some time to build the post and factor that into the pricing equation
These posts are available everywhere at lumbar yards. Really no need to make them. They also come with a 50 year guaranty. Anything happens not only will they replace the post but they'll pay to have the new ones put in. At least this was the warranty on the last ones I got.
Lumber yard versions seems to be expensive vs getting 3 boards and gluing/nailing them together.
   / Construction of Laminated posts for Pole Barn #56
On my sons house we used ”, ”, [emoji6]” and [emoji[emoji6]]” LVLs depending on the load that needed to be supported. Yes they aint cheap.
   / Construction of Laminated posts for Pole Barn #57
Dreaded gremlins attacked my post. Should read twelve fourteen sixteen and eighteen inch LVLs.
   / Construction of Laminated posts for Pole Barn #58
top 2 are CCA 0.6
Bottom one is just "ground contact" and I dont see a CCA value. It says "Ground contact level treatment (.15 pcf) has more than double the preservative of above ground level treated wood (.07 pcf)"
But I guess for $4, or $12 per pole get the CCA 0.6
But watch the prices. At Menards the 12 footers are much less than the 8 and 10s. And the 20 footer is less than two 10 footers!
(sorry to resurrect this thread)
   / Construction of Laminated posts for Pole Barn #59
Just nail them together? 3" galvanized, 3 nails every 10" or so. Both side for the first two boards and then just the one side for the 3rd? Or some adhesive also?
Woods DS8.50 (A53317)
2018 FREIGHTLINER CASCADIA 126 SLEEPER (A57880)
2018 FREIGHTLINER...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
2018 Ford F150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F150 4x4...
2021 Caterpillar 299D3 (A53317)
2021 Caterpillar...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
