This is kind of like boats, where people get "two-foot-itis" and want to move up to the next size, but it often makes more sense to move up two sizes. But then you get into issues dealing with towing, storage, etc. Sometimes you realize what you have is perfect.
With tractors, you have factors like loader capacity, horsepower, PTO horsepower, and weight to consider. Sometimes going up doesn't actually give big gains in one area or the other. Of all the factors, I think weight should be the #1 consideration. If you look at a
B2650 and
L2501, it's the weight of the L that makes it much more of a workhorse -- all other specs are either in favor of the B or inconclusive.
I started with a
B2920, which was a 3HP upgrade over the
B2620. It was $700 more, and knowing I'd be running a PTO wood
chipper, I decided getting some extra horsepower was worthwhile. In terms of the actual work the tractor could do, it was kind of moot. The 2920 definitely felt like more of a hot rod when driving around, but for pulling or ground engaging tasks it was limited by traction, so the extra HP didn't help at all compared to a
B2620.
I loved that
B2920, and it was like a mountain goat in the woods. But for large scale activities out in the open, it was starting to feel small and I was realizing the limitations of the loader. I went to look at the
B3200/
B3300, which has the same frame/size/tires as the current
B2650/
B3350. Yeah, they were bigger, but not notably heavier-duty than my
B2920. They were really just bigger B models with the same construction. Then I looked at the L models and that's were I saw a obvious upgrade in duty and capability.
So for the current situation, I think I'd lump both the
B2601 and
B2650/
B3350 into the same range. Coming from a BX, the
B2650 makes more sense, but if you had to stick with a
B2601 for other considerations such as storage, then it wouldn't be the end of the world. The 2601 and 2650 are closer related than the specs would suggest.
