compressed gas conversion for diesel engine
   / compressed gas conversion for diesel engine #1
Ken
Veteran Member
North Central Arkansas
John Deere 4520,
A neighbor drove in with a compressed natural gas converted Suv. and in talking to him is going to get his Cummons diesel truck with a conversion also.Says it requires a computer to pulse the CNG gas into engine along with the injectors for diesel.
I have never read where this is possible and what does it take to get this conversion.
so that it is reliable to run.
I have seen propane conversion to put into manifold line and just bleed into engine.air intake.
Anyone here know of this CNG and diesel conversion ? How much is original cost.
ken
   / compressed gas conversion for diesel engine #2
I can't answer your question but a couple of months ago I saw the CEO of Cummins on CNBC predicting that in five years new Class 8 trucks will be compressed natural gas powered.
   / compressed gas conversion for diesel engine #3
Why would they want to use compressed natural gas? LNG would be more appropriate and much easier to store, just like propane. The company I work for is the world leader in building LNG plants all over the world for ease of transport from producer to user. I am working on one now. They also have to build gasifier plants at unloading facilities to put it into pipelines for domestic distribution. With a demand for LNG for trucks and cars, it could easily be moved just like propane to service stations rather than turned back to a gas. At least some of it could be used that way and more and more diverted as demand grows.
This would make more sense to use natural gas than high pressure hydrogen for example.
The best use of excess natural gas is to convert it to a gas oil to be turned into diesel. The last plant I worked in was a gas to liquids plant in Nigeria that did just that. They had no use for the natural gas but plenty of use for diesel for all their cars and trucks.
Gary
There is SWN that is buying in Conway compressed gas pick-ups and cars.and also some one is converting there Dodge Cummons diesel to compressed gas with a 30/70 ratio wih a computer controlling the flow. and taping into injector to mix the gas diesel fuel this is not the manifold method of using like gas engine use.
Don't myself know more than looking for information.
With natural gas selling 1.60 pump price it would be nice to use.
Realized when more using it will increase.
ken
   / compressed gas conversion for diesel engine #5
I have investigated this conversion when I was running a fleet of alternative fuel vehicles, CNG , Methanol, M85, E85 and electric. These were classified as co-fueled engines as opposed to dual fueled engines that could switch from one fuel to another eg. gasoline and NG. The fleet I was working with were mostly class 8 trucks, however, we did have smaller vehicles. When the first technology was introduced a unit similar to a throttle body was put into the intake system and metered NG into the intake which was ignited by a Diesel "spark". Later systems used a PWM signal to a NG fuel injector mounted in the intake system. The systems worked well but were best suited for vehicles under a heavy load, at idle or low power most of the fuel used was still Diesel. It works and given the right application could work very well.
LNG is an alternative storage method but problematic due to its cryogenic storage requirements. Still not practical for the average consumer to manage. Cryogenic fluid training is required for safe handling and storage. The engines for CNG and LNG are the same only the fuel storage system is different.
   / compressed gas conversion for diesel engine #6
Cryogenic storage in mobile applications is a problem. A LP hose jammed into an intake manifold is just hillbilly behind the barn engineering. A diesel will operate just fine with pilot injection of an idle quantity of fuel. NG is added to increase power output. Even if all vehicles and equipment were converted to LP, NG etc. the green weenies in the EPA, CAFE and CARB will just invent more regulations to virtually ban them too. The green weenies visualize a perfect world with no roads, factories, refineries etc. With them all wearing white robes on the hill side singing Kumby-Ya. Then dine on a tofu and lettuce buffet.
The compressed gas being used as fuel has a CO2 less than gas or diesel powered trucks
With same safety standreds as gasoline. meets the Nat. Fire Protection standreds
Looking for some one who has converted there diesel truck to CNG and diesel for every day use.
There is all kinds of information on gas vehicles and the conversion so far over looked any on diesel engines.
ken
   / compressed gas conversion for diesel engine #8
ken
The range of a compressed NG machine is short unless it's towing it's own fuel tanker.
   / compressed gas conversion for diesel engine #9
Care to provide evidence for your statement?
   / compressed gas conversion for diesel engine #10
CNG verges on being useless as the range from a 60 litre tank is woeful , enough to get you to the next filling point of which there are very few.
We have a fleet of CNG buses here in OZ and they had to strengthen the chassis to carry the additional weight of all the gas bottles so as to get a decent range
Further they take an eternity to refuel i.e. a 60 litre tank about 5 minutes at best
LPG injection in a diesel now thats a different matter works exceptionally well and produces significant gains in power and economy
Do not recommend CNG at all , run and run fast away from it
2021 Nissan Versa SV Sedan (A48082)
2021 Nissan Versa...
UNUSED Clear Multi-Wall Polycarbonate Panels (A50860)
UNUSED Clear...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2011 BMW 128i Convertible (A48082)
2011 BMW 128i...
