Clogged grease fittings
   / Clogged grease fittings #13
Have you tried a different gun? Usually those things develop enough pressure to blow through anything. Seems very strange to have this problem in multiple locations. The handle guns generate more pressure than the pistol type guns.
the guns are color coded for presser;)
   / Clogged grease fittings #14
the answer to your problem can be fixed easy get a long grease fitting load with as much presser you can get in it then start working it-- the tractor ---if it dose not pop in a couple uses presser it again and put the heat to it the spot that is to take the grease some times a little film of metal forms over and stops the grease ----KEEP YOUR FACE AWAY ------from the fitting just in-case it pops :thumbsup:
HONDA EG3500 GAS GENERATOR (A52707)
HONDA EG3500 GAS...
SCAN TO RECEIVE TEXT UPDATES (A57192)
SCAN TO RECEIVE...
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
2019 BOBCAT T595 SKID STEER (A52707)
2019 BOBCAT T595...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
(4) 10 LUG BUD RIM WHEELS (A57192)
(4) 10 LUG BUD RIM...
