Clogged grease fittings
   / Clogged grease fittings #13
Have you tried a different gun? Usually those things develop enough pressure to blow through anything. Seems very strange to have this problem in multiple locations. The handle guns generate more pressure than the pistol type guns.
the guns are color coded for presser;)
   / Clogged grease fittings #14
the answer to your problem can be fixed easy get a long grease fitting load with as much presser you can get in it then start working it-- the tractor ---if it dose not pop in a couple uses presser it again and put the heat to it the spot that is to take the grease some times a little film of metal forms over and stops the grease ----KEEP YOUR FACE AWAY ------from the fitting just in-case it pops :thumbsup:
RED-D ARC INC.WELDERENTALS DC600 CV/CC ARC WELDER (A57192)
RED-D ARC...
Selco V5-HD Vertical Hydraulic Baler (A55851)
Selco V5-HD...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2003 PETERBUILT PB330 DUMP TRUCK (A57192)
2003 PETERBUILT...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
