Clearing land
   / Clearing land #1
1falcondriver
John Deere 4610 4x4
I'm new to the forum...just bought 15 acres of land and a JD 4610 (4x4 fel). I need to clear the land. It's a pine plantation about 18 years old. I won't be clear cutting just cleaning up for a house place. What brush cutter should I be looking for? Most of the stuff I'll be cutting is 3" or smaller around the pines?
The 4610 is 43hp 37@the PTO
   / Clearing land #2
If you just use a cutter, you will end up with stubs sticking up, not a very nice home environment and not one easy to keep mowed.
I had a situation like yours years ago although the trees were a bit bigger (4-5") and were red maple. I cut them off a couple of feet high with a chain saw, then used the ripper teeth on a box blade to pull the stumps. Some were harder and I used a single big tooth ripper attachment. I probably should have cut them off shorter, more like 6-12" high.
That's all I had for equipment back then. Now I would recommend a backhoe (rent one if you need to) to do the work.
Ken
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2020 Chevrolet Malibu LT Sedan (A50860)
2020 Chevrolet...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
