Cleaning up Brush with the 45
   / Cleaning up Brush with the 45 #1
Oleozz
Veteran Member
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
I have started to clean up brush piles of pine trees that were originally planted as Christmas trees but then got to big. They were bulldozed down and piled up with lots of dirt in the piles. I wanted to clean up the brush and the dirt, I am using an add on tooth bar and a add on grapple. So far they have worked well.
This is a pic with some brush on and almost a full load of dirt. Doesn't look big until you start lifting all that soil, has a good bit of weight to it.
   / Cleaning up Brush with the 45 #5
That sure is a mean looking front end isn't it?
I'm sure a regular grapple with plenty of room for dirt to fall through would probably work better, but you've got the right idea. The extra length of the toothbar teeth can really help to pick up brush without the dirt.
That 45S is a real hoss!
John
EDIT:
Are you able to come down on the pile in a near-dump position and pick the stuff up so much of the dirt falls out?
   / Cleaning up Brush with the 45 #6
John
EDIT:
   / Cleaning up Brush with the 45 #7
Oleozz,
That is one beautiful, bad machine!
You are having way to much fun!
CT_Jeff
   / Cleaning up Brush with the 45 #8
Oleozz,
CT_Jeff
   / Cleaning up Brush with the 45 #9
That would have been one burly xmas tree on the left in your mouthfull picture.
I also have a bunch of piles of dirty brush that need to be seperated and burned. Does the woody debris come clean enough to burn in a reasonably sized fire? I realize that a hot enough fire will burn dirt.
How is the top of your bucket handling the grapple stress?
   / Cleaning up Brush with the 45 #10
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
1995 FORD DUMP TRUCK (A51222)
1995 FORD DUMP...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
