Clacking noise in my L4330
   / Clacking noise in my L4330 #1
tanman
Near Albany NY
L4330
On my right side (when driving forward and in reverse) I here a clacking noise. It use to be faint and very rare, but the more I use it, the more common and louder It is starting to get. Ideas anyone??
   / Clacking noise in my L4330 #2
If you have a front end loader, Grease all the zerks really well. I had the same noise and thought that my engine was faulty. Turns out it was the loader making the noise.
The noise is in the rear though.
   / Clacking noise in my L4330 #4
Check the wheel bolts.
Kevin,,
Thank uuuuuuuuuuuuuu.... You were right on the money. One of the (inside) bolts were loose. Where do I send the check?? :) Thanx
2013 Volkswagen Passat Sedan (A48082)
2013 Volkswagen...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2007 Ford Escape AWD SUV (A48082)
2007 Ford Escape...
80in HD Tooth Bucket with Side Cutters (A51039)
80in HD Tooth...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
