ck4010 not starting
   / ck4010 not starting #1
Tigershark
Shelby, KY
KIOTI NX5510 Cab HST with Backhoe
Ran all day yesterday and today fine parked it and went to start it after a short break and got nothing but a dashboard full of lights. Fuses looked fine hadn't engaged the PTO. Not sure where to start any thoughts? Tractor is 3 yrs old barn kept no noticeable issues with wires under the hood Weird that is was running fine and now won't turn over Thanks for any help
   / ck4010 not starting #2
Ignition switch issues, use a test light on the starter solenoid wire and see if it powers up when you try to crank it over.
I think some are using WD40 in the lock cylinder itself. Mine stays indoors when I'm not using it but the ign switch feels funky already.
thank you will give that a try
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
5K BLOWOUT PREVENTER (A50854)
5K BLOWOUT...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2011 International School Bus (A49461)
2011 International...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
