Ck2610 HST
   / Ck2610 HST #1
Bigrackslayer
Bronze Member
Eganville Ontario Canada
Kioti CK2610 HST
Hey everyone I just purchased a ck2610 HST it will be deliveried Friday. Was just wondering if anyone here has any experience with a tractor like this and have some tips or tricks or any info for me. Thanks in advance.
   / Ck2610 HST #2
I have about 15 hours on mine, Love it so far, i cant tell you any tips or tricks as it really doesnt need anything extra to make it work for ya.
one thing that kind of sucks, is no toolbox on this tractor.
But an easy solution is an ammo can tool box. There is plenty of extra holes and screw holes to go with to attach it and is real easy, i am working on making a bracket to help support for my placement, as i didnt drill an holes.
Other than that it is a nice machine and will work well for ya.
   / Ck2610 HST #3
Have a real good look over during next few hours of operation. There always seems to be a bolt/nut or hose loose from dealer assembly. Certainly no big deal, its just nice to find before you loose the hardware.
Nice lookin rig :thumbsup:
   / Ck2610 HST
Thanks guys. Mine actually came with a tool box which is mounted to the ROPS. it's not very big but will do for now till I can find a nice size tool box for it. Really looking forward to putting some hours on it this weekend. My dealer had my tractor on there dyno I'm super impressed with the HP Numbers it's pumping out!! I can't wait to do some customizing to the tractor like chain holder and chainsaw holder and a few other little touches I'd like to add!
   / Ck2610 HST
The brochure states that gross hp is 24.5 and pto hp is 21.5. The dyno showed 24 pto hp and gross at 28 hp. Now I know those aren't huge increases but I'm happy with what's pumping out.
   / Ck2610 HST #7
Torque all the wheel bolts/nuts and loader mount bolts to spec. Do it again after 50 hours or so, then check periodically. Not sure, but I suspect the paint compresses enough to let these bolts get lose and that can oval-out the holes. You really don't want that. So keep checking for a while.
Inspect everything carefully. Some of the loader pins were swapped on mine such that some had two grease fittings and some had none.
While it's all new, take the shop manual and "walk through" the 50 hour service schedule to get familiar with everything: see it and touch it.
Oh yeah, READ the owners' manual.
   / Ck2610 HST #8
On the advice of my Kioti dealer, (after I appeared looking to buy replacement spring type pins), I started changing to cotter pins whenever/wherever possible. The 3pth had many that used either the hairpin retaining clips or similar, most fell off sooner or later.
   / Ck2610 HST #9
Get some locktite on the bucket level rod threads. I bent mine within 10hrs.
   / Ck2610 HST
Thanks for the replies everyone I'll watch closely the first few hours for anything loose and I'll watch the pins and check out the bucket level rods. Thank you
2006 Volvo VNL (A51039)
2006 Volvo VNL...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
