CK 35 hydraulic filter protection
   / CK 35 hydraulic filter protection #1
jabelding
Maine
2014 Kioti CK35 2015 CS2410
Hi Everyone
Just replaced my 80's kubota L275 with a 2015 Kioti CK35 what a difference! easier starting much faster loader and great backhoe.
One thing i noticed is that the hydraulic filter hangs down quite low and i will be using it in the woods for some fire wood logging and worried about ripping it off. I already dented the end of it with the backhoe frame.
Has anyone made up a shield for theirs? Any ideas would be great.
Thanks
JB
New CK35
Old L275 time to sell
   / CK 35 hydraulic filter protection #2
Hi. Welcome.
That old L has another 20 years in it.:)
That filter on the CK looks like it is in a tough spot to add a shield. Maybe some 4 inch angle iron placed in front and back of it to shield it.
   / CK 35 hydraulic filter protection #3
I did knock mine right off once. I was bogged and put a ramp down to drive onto. The ramp skidded back and next thing there is oil everywhere. I haven't made a guard for it yet but I am very aware of it.
   / CK 35 hydraulic filter protection #4
Have you tried a site wide search? Use various terms like skid plate, belly pan, etc
A year back or so, someone put a belly plate on theirs. I think they fabricated it out of diamond plate and went with some longer bolts at existing points to mount.
   / CK 35 hydraulic filter protection #5
I made something like that and work great.....
Looks great pekan!
I have mine mostly done both the frame and base plate are finished just need to make up the sides then paint it up pretty. I went with the filter trap door that I had seen on some other ones. Had a challenge keeping it up tight to miss the backhoe frame.
   / CK 35 hydraulic filter protection #7
Is it possible to relocate the filter altogether?
Not great placement to begin with.
It would be hard to move with all of the hard lines holding it. One of the lines comes out of the base of the transmission.
   / CK 35 hydraulic filter protection #9
I think Michigan Iron used to make and sell a protective shield for that filter. Might want to check them. I've seen other homemade versions from expanded metal.
   / CK 35 hydraulic filter protection #10
1996 Ford F-350 Flatbed Truck, VIN # 2FDKF38G8TLA64077 (A57453)
1996 Ford F-350...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59575)
2005 INTERNATIONAL...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
