chinese chipper
   / chinese chipper #1
gino45
Hawaii
kubota b7100
weighing in the neighborhood of 800 lbs. How would my Kubota B2710 handle moving this around my farm? Tractor has fluid in tires and a front end loader.
   / chinese chipper #2
I use a 6" Farm Pro (Jinma) with my B2910 with no problems .. I would think you would be fine .... provided you have a FEL on the B2710.
   / chinese chipper #3
My B7800 lifts it easily but the unit is quite top-heavy. I also use a Pat's Easy change which moves it back another 3 inches or so, which makes the weight distribution even worse.
I find that lifting it all the way up can make the tractor quite tippy on slopes that I would normally have no problem with. I lower it until it just clears the ground, and drive very cautiously across such spots.
You might also check with other 2710 owners to see if your HP is adequate. I would consider the B2910 or B7800 as minimal if you are chipping near its capacity.
I'm one of the owners that have had good experiences with it overall.
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
Misc. Electronics (A50860)
Misc. Electronics...
London Fog 18-20 Mosquito Machine (A50860)
London Fog 18-20...
