Charging Light
   / Charging Light #1
silverdollar6
Finger,Tn
ym1610d
I have a ym1610d that after running about 10 minutes you can see a faint light on the dash, I guess it is in the battery charging window, it will go out if I turn the headlights on, would this be some kind of feedback from a bad ground. I put a new voltage regulator on it about four monthes ago for this reason.
   / Charging Light #2
Kind of hard to respond if you don't know for sure what light is coming on.
   / Charging Light #3
George, that sounds identical to the symptoms my YM2220D was presenting a while back. Replacing the regulator appears to have solved my problem. I notice you recently installed a new regulator. Did this problem predate the new requlator or did it appear later?
   / Charging Light #4
What RPM does this occur? Idle or running speed?
   / Charging Light
sorry about the lack of info, I am sure it is the charging light, the one with the lighting bolt. this is the reason that I put the new regulator on, I thought that fixed it but after it warms up a little the light comes on real faint at first then will get a little brighter as I run. if I reduce rpm it gets dimmer.
   / Charging Light #6
What voltage does your battery show at about 1500 rpm? Sounds like it's indicating an over-charge condition, brightens with higher rpm, dims at idle, and/or more current draw.
   / Charging Light #7
seems strange for the charging / alt.light to go out when you turn the head lights on
   / Charging Light #8
If it is an overcharge indication, turning on the headlights could soak up the "extra" current. Yeah, I know, I'm reaching.
This is very similar to a problem I had a few months ago on my YM2220D and described in this thread. Here is a thread on what looks to be the same or similar occurrence in another YM1610D.
My problem was cured (so far) with a new regulator. The OP indicates that his regulator was recently replaced. Wonder if there is some undiagnosed electrical problem that is repeatedly wiping out his regulators? I understand that solid state devices can be sensitive to overvoltage surges, reversed voltages/currents, etc.
   / Charging Light #9
Tom ,I guess I wasn't thinking of the light comming on on an over charge situtation. Would the light come on in an over charge sitiation ?
   / Charging Light #10
kenmac said:
... Would the light come on in an over charge sitiation ?
I have no idea. I seem to remember that possibility being voiced earlier in the thread and was replying with that in mind.
I know when my problem first started, the light was very dim and turning on the headlights made it go out. Don't know how, don't know why. Later on, the situation progressed to the point that when the light came on, it came on bright and stayed that way, headlights or no headlights.
2017 Ford Explorer SUV (A46684)
2017 Ford Explorer...
Irrigation Reel (A49251)
Irrigation Reel...
2011 BMW 128i Convertible (A46684)
2011 BMW 128i...
Hesston 530 Baler (A49251)
Hesston 530 Baler...
2016 John Deere 3038E Front Loader Utility Tractor (A46683)
2016 John Deere...
2017 Peterbilt 567 Tri-Axle Dump Truck (A46683)
2017 Peterbilt 567...
