Changing Hyd. Oil Filter-L4300
   / Changing Hyd. Oil Filter-L4300 #1
Bob_Young
Veteran Member
North of the Fingerlakes - NY
Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Reviewing the L4300 manual, I notice that the first step for changing the hydraulic oil filter is to drain all the transmission oil; over 10 gallons. If you're going to be CHANGING the transmission oil (400 hrs.), that's fine; but if it's only a filter change (200 hrs.) the 10 gallons plus of drained oil has to go back in the tractor. Seems like there's a good chance for oil contamination.
Is it necessary to drain the tranny prior to changing the filter? If you don't drain, will the transmission oil run out of the filter fitting until you get the new filter on? Does it make sense to accept the fluid loss during the change and then top off afterwards?
Thanks.
Bob
   / Changing Hyd. Oil Filter-L4300 #2
I know on my L2800 it is a gusher running out of the filter boss. I would bet you would get a little wet/oily. I would say you better be quick.
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
UNUSED U Bolt Wire Rope Clamp Set (A50860)
UNUSED U Bolt Wire...
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
Lot of 5 Dell Laptops (A48083)
Lot of 5 Dell...
1991 Deere 750B Long Track Crawler Dozer (A50860)
1991 Deere 750B...
