RalphVa
Super Member
- Joined
- Dec 19, 2003
- Messages
- 7,885
- Location
- Charlottesville, VA, USA
- Tractor
- JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
I was reading the B2301/2601 owners manual online. Even Kubota recommends changing the engine coolant every 2 years.
What is different about a tractor's coolant vs. car/trucks that go 10 years or 100k miles now on coolant? Think NOTHING.
There is really nothing different about a tractor's engine vs. one on a car/truck either. It's just that you HEAR it more loudly and you tend to think it's working harder. No. No harder than a car/truck engine going about its life. They're just very well noise isolated.
I'm not changing the coolant on the JD 2025R. It'll be well less than 10 years old before I trade it off (probably for a B2301). I also went to biyearly oil changes. Silly to change out every year (on a synthetic anyway). May even not change it on our JD walk behind because its dipstick has always shown crystal clear oil.
Went to longer drain periods on the 1983 after initially following those "every 2 years" recommendations way back then. Same for oil changes. Switched to synthetic and doubled the interval.
If the vehicle doesn't have one of those chambers to vent off excess or suck coolant back in, add one. I added one to my Isuzu diesels radiator. That's the main source of not being able to go longer before turning the coolant a bit acid. As far as I've experienced so far, all the new tractors have these overflow chambers, e.g. little plastic containers where you replenish any needed coolant and can easily see the level without removing the radiator cap (another source of air).
Ralph
Ralph
