Challenger MT555D tractor heading my way
   / Challenger MT555D tractor heading my way #1
Hay Dude
Epic Contributor
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
   / Challenger MT555D tractor heading my way #2
That's a big machine, will it be your largest? Very cool; is the kid in you excited?
Out of the 4 I will have it will be my 3rd smallest. The Massey 7495 is 200HP and the Challenger MT655E is 300HP are both bigger. Only the Challenger MT535B is smaller.
I’m semi-excited. The machine needs a little work on software programming, then I’ll be more excited. ;)
   / Challenger MT555D tractor heading my way #5
Looks to be in great shape. Do you know much about the history of this machine. Do you have an immediate use for it, did you pick up some new work were you needed it, or did you just want to have a machine with a grapple added to your fleet ?
The dealer gave me the phone number of the previous owner. I spoke with him for about 15 minutes. He said his area lacked dealer support (which kind of surprised me) and he traded it on a new Deere IVT. I am still a bit apprehensive, but my dealer thinks the tractor needs a re-flash and that his dealer was incompetent.
Yes, my plan is to use it to supplement, if not completely replace, the Challenger 535B, which is really getting a lot of hours put on it. I could put the 555D to work loading bales pretty much as soon as it gets here since I still have a few hundred to sell.
What I’d like to do is change the role of the slightly smaller 535B to being attached to the Deere CX-15 for field mowing/bush hogging and other types of property maintenance (log loading, snow plowing, etc.)
The 555D would become the new(er) raking, teddering and bale moving/loading tractor and accompany the baling tractor during hay season.
The 555D has a one step larger loader than the 535B and although the Quicke Q66 on the 535B was plenty stout for the job, this ML-78 (Quicke builds Challenger loaders and calls the ML-78 a Q7) should be even heavier built. It also has a nice set of cast iron double wheel weights.
I might remove one set and add that set to the 535B since I don’t need double wheel weights on the 555D.
Even more important is the 2 tractors are similar enough that they can fill in each-other role should one of them have an issue.
We shall see. Buying used equipment comes with risk, free of charge. Hopefully I get away with minimal fix up costs.
Loader specs
It’ll lift 2&3/4 tons to full height. I need to be able to lift 2 tons to 3/4 height (2 bales at 1,800LB -2,000LB + 500LB bale spear). So the loader should be fine.
   / Challenger MT555D tractor heading my way #8
Where did you buy it? From a dealer or an individual? How far is it from you? 3-4 weeks seems like a long time for delivery.
John Deere dealer. The previous owner traded it in on a new Deere IVT @ $250,000. Good luck with that
I think it’s 1,100 miles
Really? With the Thanksgiving Holiday, I thought that was pretty reasonable (16 days from today)
I asked if they could delay it a bit too. I have enough messes in life right now to deal with.
It’s not like they’re going to send someone out the next day, they have a lot of shipments booked.
2023 Kubota Z252KH-54 Zero Turn Mower (A55315)
2023 Kubota...
2020 DRAGON ESP...
40' High Cube Multi-Door Shipping Container (A56469)
40' High Cube...
Takeuchi TL12V2 (A53317)
Takeuchi TL12V2...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
