Chain Saw Recommendations - not a professional one please
/ Chain Saw Recommendations - not a professional one please #1
doxford jim
Veteran Member
British Columbia, Canada
1959 MF-65 sold, 2007 Jinma 554 diesel.
Hi all,
After readings 3RRL's thread on Chain Saw Cart, it got me thinking about chains saws.
I am fairly new to the world of chain saws and own a second hand McCulloch 20" saw. It works Ok but does seem to be in constant need of TLC.
I have several mature trees blown down in recent stormy weather and would like to be able to deal with cutting them up without too many problems. I could spend money on replacing various parts on the old saw or, cough up money and buy a new one for a little more.
So my question to all you experienced "chain sawers" is what would you recommend for a home owner, using it on a now and then basis. Money is a consideration (am retired) and would like to be able to get a good buy (who wouldn't). I don't want a professional grade unit so hopefully, the price would be more reasonable.
I have tried looking at reviews and the Poulan Pro 20" seems to get 4 stars out of 5 - but also a lot of comments on starting problems and stalling. I figure some of these would be down to using stale gas or the wrong mixture.
As you can see, I am trying to spend as little as possible - though not necessarily the cheapest.
Any input and/or pearls of wisdom would be greatly appreciated.
Thanks guys.
Jim
/ Chain Saw Recommendations - not a professional one please #2
I have Echo chainsaws that for the cost are one of the better values I think. I own Stihl's and Husky's as well. What ever you buy the best advice is use good gas and mix. Then when the saw is going to sit for more than a few days run it out of gas completely. You can either dump it back in the gas can or just run it out. Don't keep mixed gas around too long. Putting Stabil or even some of the 2 cycle mixes have that in it. The gas mix I use is called Opti 2. That is one of the best mixes you can get.
Those old saws are ok but they aren't doing you any good if you get tired just starting it.
/ Chain Saw Recommendations - not a professional one please #3
If you have access to power consider an electric chain saw. My cheap Canadian tire model has been going strong for 30 years now although some of the plastic parts may be missing. Think I'm on the third bar. :)
If the use is infrequent and cost is a consideration find one of the inexpensive ones from a chain store. If it works good for the present cutting all is fine. If it doesn't take it back.:)
Note: I'm not an experienced Sawyer but have worn out several saws.One was a reputable brand.
/ Chain Saw Recommendations - not a professional one please #4
I have had great luck with my Poulan Pro. The only complaint is it can be hard to start when hot and working in 85 plus deg temps. I only cut 2-3 truck loads a year so I really do not need anything too fancy. The other thing I like is the chains are cheap at WalMart. I get a 2 pack for under $24.
Chris
/ Chain Saw Recommendations - not a professional one please #5
Jim
Given that you are in Canada I think you will find that ECHO, Dolmar and others are for some reason priced quite high. You can't go wrong with a Stihl like the MS 290. Given your retired state the saw will probably last longer than you will be able to use it. The Poulins are, for the money pretty good value.Lots of my neighbours use them as their "truck saw" and they see a lot of abuse. I am about to part out an old MaC that I inherited and will probably buy a cheapy Poulin as my backup saw. JMHO
/ Chain Saw Recommendations - not a professional one please #6
You don't write on the saw size (CC or CU. IN.).
I've two 35CC's that I run 16" bars.
I've a 62CC John Deere CS 62 that I run a 20" bar and a 28" bar for milling.
I've a 92CC Stihl 660 that I run a 28" bar and a 42" bar for milling. But lot's of people run 20" bars on these.
If your Mac is about 50 to 60CC give it some TLC. A new properly gapped plug ($3) a new filter, a new chain. Run some Seafoam thru it with high octane fuel and good oil. Check the sprocket. Make sure it's tuned properly. It's liable to last a while.
If you NEED to run a 20" bar you need a pro saw.
Look on ebay for some reputable sellers, you can probably pick up a good suitable sized saw for < $400.
Like others wrote old gas is BAD gas.
/ Chain Saw Recommendations - not a professional one please #7
I have echo and Stihl I like the echo better
joel
/ Chain Saw Recommendations - not a professional one please #8
Get one with a compression release. Starting becomes so much easier.
I have a Husky 345 -- not the pro level, but one down. Works pretty well for me.
Always use premium gas and always add a double dose of Stabil as well as the oil.
/ Chain Saw Recommendations - not a professional one please #9
Hi all,
Thanks guys.
Jim
Find a good Stihl dealer and talk to them about what you need. You will find what you need and with a Stihl you will not be disappointed.
/ Chain Saw Recommendations - not a professional one please #10
How old is your saw? Does the Mcullogh have the hand brake / kickback brake? If not, you should probably buy a new one.
How big are the trees you are wacking? That will predicate your purchase.
For the ordinary homeowner, I think any name brand should be fine. Stihls and Husky's are very popular in our area, with Husky's being the one I see most in loggers trucks. Followed close by Stihl. But you need your gold card to buy in in our area.
/ Chain Saw Recommendations - not a professional one please #11
I've had 2 Poulan Pro's and now own a Stilh MS 192. Like you I only will use it occasionally. At most 1-2 cords of firewood per year and the occasional clearing of dead wood. My first Poulan Pro I had for 9 years and neglected it and never had a problem with it. Stored it for months with fuel and then would just add bar oil which had drained and it would start easily by the fourth or fith pull and then run well for as long as I needed it. Sold that one when I moved and then bought another last year when I bought the current property. That Poulan lasted only a couple of months and was continually hard to start and keep running. Serviced twice with no improvement in manners. It finaly did me the favor of dying and I have no intention of trying to resurect it incase it decides to continue to give me more headaches. Went and bought the lightest weight Stilh I could find and could not be happier. Smooooth, powerful for it's size and has been ultra reliable for the 2 cords of fire wood and deadwood clearing I've done.
Not the cheapest saw for it's size but I'm happier than with a saw that was cheaper but continually gave me grief. I have no idea why there was such a difference in manners between the two Poulans (maybe just the odd lemon) but it soured me on the brand.
/ Chain Saw Recommendations - not a professional one please #12
Do you have to have a new one? You could save money by buying a used name brand....Ebay or Craigslist....I bought a used Husky at an auction, my dad gave me his small Husky, and I have a BIG Husky, all great saws. I see everyone ranting and raving about the 346XP on the Husky site...but I think they're about $400 new. Good luck!
/ Chain Saw Recommendations - not a professional one please #13
I'm a Stihl man. I bought a small Stihl 14" model last year, as most of the stuff that I would have to cut wasn't big and I wanted something small for the back of my ATV for doing trail maintenance at my club. I have an older, bigger 18" Craftsman (made by Poulan and equivalent to a Poulan Pro) as well. I've used the Craftsman once since I got the Stihl and that was just to burn up what was left of the fuel in the tank. The Stihl will cut much more than you would think by its size. I've taken down numerous trees with it, if the trees were bigger than my bar, I just needed to make 2 cuts. This saw just runs faster and cuts better than just about any other homeowner grade saw that I've ever used. Even though Stihl considers this saw a homeowner saw and prices it not that much higher than other homeowner saws, to me it has been much better. I don't see myself ever buying anything other than a Stihl.
/ Chain Saw Recommendations - not a professional one please #14
I have the Husky 350, one size larger, and really like it. It starts MUCH easier than the little Stihl 011 trim saw I have... lots of power for its weight also.
If I were cutting wood for a living or hardwood as a primary heat source, I might recommend going to one of the Husky XPs for even more HP per pound. But, the Husky 345/350/355 are good homeowner saws, IMO...
/ Chain Saw Recommendations - not a professional one please #15
I have two Husqvarna saws.
One is a 23 year old 40 cc, (15 inch bar) the other is a 55 (18 inch bar) maybe ten or twelve years old. Both have plenty of power and both have cut lots of wood.
Either one would probably fill the bill for you, but you'll spend about $400 ...and that's on the cheap side.
If I were you -older, apparently less experienced with a saw- I might consider having a professional woodcutter come in and give me a price.
He might do it for what a new saw would cost and you'd be spared the hazard involved.
I'm not trying to insult you at all, but even sawing up fallen trees can be tricky (dangerous). Attempting it when the years have taken their toll on your nimbleness?
I dunno, I might just pay someone else and have the old Mac fixed up for when you really need it.
/ Chain Saw Recommendations - not a professional one please #16
I bought a Stihl MS290 last year and I love it. It's lacks the anti vibe features but thats not an issue for me since I only run one tank through at a time. That makes quite a pile of firewood. I give my hands a break while I split and stack for the rest of the evening.
/ Chain Saw Recommendations - not a professional one please #17
I grew up with chainsaws. I would talk to a STIHL dealer and see what would best suit you. Huskies are OK, don't waste your money on a Walmart Poulan, you'll spend more time working on getting it started, than cutting wood. I like a mid weight/power models for versatility.
/ Chain Saw Recommendations - not a professional one please #18
I also have the Stihl MS290, mine has the 18" bar. It has always required about 5 pulls when is sits for a few days, after that it starts easily.
/ Chain Saw Recommendations - not a professional one please #19
I have two Stihl saws - the ms250 and the ms260 . . . They are both great saws. I run a 16" bar on the lighter 250 and a 20" bar on the 260 . . . one thing to consider is that with the 20" bar, I don' have to bend as far to cut wood on the ground. I have a bad back and the longer bar really works great for me. Even though the 260 is a significantly heavier saw, its longer bar makes it easier for me to use (it's also a much more powerful saw).
/ Chain Saw Recommendations - not a professional one please #20
I have a 10 y.o. Craftsman 18" 42 cc. I want a bigger saw but can't justify it while this thing is still running. I have kept the Craftsman in its case when not in use and it has served me well. Starts on the second or third pull. With this particular saw, one pull on full choke, and then push the choke in about 1/2 way and another one or two pulls she runs great. I know its not a pro saw and I don't try to abuse it. I used to heat with wood and we did use a pro McCullough with a 24" bar. Now it would sure eat the wood but it was heavier. I agree with the others about fresh fuel and mix, and using an additive like Stabil or similar pre-mixed oil/stabilizer. I use mine on a fairly regular basis now as I collect fire wood for the hunting lease, but it is still only once or twice a month at most and very little in the summer, if at all. Plus I think I got it on sale for about $150.00. I can't beat that value. Again, I do take care of it as I try with all my equipment.
