David VanName
I recently put my jd 855 compact tractor back in use. It ran fine for about 10 hours and then the 3 point hitch arms began to pulsate when in the lift position with an implement on. I had split the tractor to have some welding done on the rear differential front cover, so all the linkage was taken apart, as well as the front cover removed from the differential. This exposed all the gearing forward of the differential. I have looked at linkage as a possible cause so far. It is possible that the pulsating was there right from the moment I put it back together and I would not have noticed it because I hadn't used any implements other than the bucket.
