Tiller Cat 0 tiller adapt to a Cat I?
   / Cat 0 tiller adapt to a Cat I? #11
BTackett said:
I feel like a dummy. I do have a 3 speed PTO. I think from reading other users that it is a 540,770,1200 rpms. I would think the 1200 would probably work.
Still trying to decide which way to go without dropping $$$ on a tiller.
thanks
Bill
Ok now that you have that out of the way:) You can use Cat 1 implements on your 372, I know I do it with mine. The PTO hp is 14.
My tiller is an 400lb 45" Agric gear drive 1300.00 shipped to the truck treminal. I wanted one lighter than the 600lb 48" KK, I would have paid the same for the KK locally. Tire width on my 372 with turfs is 42".
I have used my tiller for alot more than just the garden, it is a great tool.
Yep, going to have to save for that one. I finally got my 3pt lift un-stuck from the up position today by bouncing on it. Then got all happy with the lever and the weld broke off! It was moving slowly up and down and before I could add fluid it broke off. So , now I have to break out the welder and fix it and then add fluid. I also removed the fenders/hood to begin sandblasting and painting them. Check out my vise grip 3pt lift lever:cool:
Bill
   / Cat 0 tiller adapt to a Cat I? #13
While you have that seat off and your welder out you may want to upgrade to a suspension seat at this time:)
   / Cat 0 tiller adapt to a Cat I? #14
Would you be willing to sell you category 0 tiller for 200 dollars
UNUSED RAYTREE RMDM72 72" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
2017 Ford T350 Van (A55973)
2017 Ford T350 Van...
Air Compressor (A56469)
Air Compressor...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A55315)
1995 Ford F-250...
12' CONTAINER (A57193)
