Hankstone40
- Joined
- May 22, 2022
- Messages
- 3
- Tractor
- Kabota B7800
I purchased a slightly used Caroni TL 1500 flail mower. I greased the obvious spots and changed the gear box oil. After about an hour of mowing 12" pasture grass I noticed the cutting stop and smoke coming from the drive belt cover. Opened it and both belts were fried and frayed. I greased the belt stretcher bearing , replaced the belts and ran it for 20 minutes. The drive belt cover was hot and the belt stretcher cylinder was too hot to touch. The belts seemed OK but it seemed as if they would eventually melt. My theory at the moment is that the previous owner did not grease the stretch bearing that you only see when you pull the drive belt cover and the bearing for the Belt stretcher cylinder is shot. Does this sound reasonable? Any advice?
I've only found one skimpy manual online and it is very sketchy. Is there a real manual for this machine?
Hank
Hank
