Canoe
   / Canoe #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
Anyone have a good trick for carrying a canoe? I have a canoe, but it is way way too long to fit in the 8' bed on my truck.
I have transported it using my utility trailer; I can arrange it so it hangs off on both ends, but more so over the trailer tongue. Would like to be able to haul it without having to use the trailer.
I do not have lumber rack or anything like that, although it is set up to tow our 5th wheel. Just a basically stock '01 Ram2500 4x4.
   / Canoe #2
We have an Old Town Tripper, I think its right at 17'. So long in fact that we added a 3rd seat in the middle.
We haul ours by placing some type of padding on the top rear of the cab like two stadium cushions or a folded blanket. Then with the tail gate open load the canoe upside down over the cab with the back hanging over the tail gate. Like always you need to tie it in good or it becomes a massive sail. We have traveled many miles with this set up.
   / Canoe #3
I made a rack out of 2x4's that fit in the stake pockets of my bed, like a ladder or pipe rack, and tied the canoe down with small ratchet straps. Worked pretty good for occasional carry.
   / Canoe #5
I bought a 17' ouachita canoe in 1969 and a friend welded up a real nice ladder rack for my Chevy pickup. I don't know whether they still make them or not, but there used to be some pads that you put on the sides of the canoe then turn it upside down on top of your car and tie both ends.
   / Canoe #6
I've got an old Sunfish sailboat that we've had in our family for nearly 40 years. The boat had the usual leaks for something that old, and someone stole the mast and sail, so it's probably beyond spending any money to fix. But the trailer is still sound, and I'm planning to convert it to haul one or both of our canoes. It should be a fairly simple conversion. I'm thinking of setting it up to either haul the canoe right side up or upside down for storage to keep water out of it.
I've seen old Sunfish sailboats with trailers go pretty cheap at times. These trailers are not really designed to haul a heavy load, so you might look around to see if you can find one.
GGB
   / Canoe #7
To transport a canoe in the back of a truck you need either a couple of old tires for up to 14'-16' or one of those hitch extenders that add a couple feet.For my 14' aluminum in the back of my 6 1/2 ft Tundra I open the tail gate and slide the canoe in upside down. I put the two tires under the canoe on top of the tailgate and tie it down. Zero problems and have done this for 40 years with all types of canoe materials. With an 8' bed you can do a 16' canoe the same way.
If you want a canoe trailer, forget about it unless you come up with a way to carry the canoe upside down. That is the only way most of them have strength and they will eventually crack or break if you transport right side up. The keel and rib is not capable of providing support. Grumman--Marathon Group--mentions this as a warranty violation. Canoes only tranport well if they are upside down.
Another good one-person way, if you don'tlike the pickup method is to have a camper top on the truck and attach something like the Yakiima roof racks that are wide and strong. Slide one end of the canoe up on the back of the truck roof rack and slide the canoe forward. A couple of ratchet straps side to side and you're good for 80 mph. Have done it many times and with two people it's a piece of cake.
   / Canoe #8
Check Yakima or Thule.Both have any system will need.A little pricey but worth it.I have carried canoes and kayaks for many years with a Yakima system,used on multiple vehicles.Way better than a trailer.
   / Canoe #9
For the rear, I've seen something like this assembled with the short side of the "L" in the receiver and the long one vertical. The front can rest on the cab on a conventional roof rack crossbar.
Truck Bed Extender - Save on this Pickup Truck Bed Extender
Or this method:
Econo Truck Rack | Kargo Master | Heavy-Duty Pro II Steel Truck Racks | Cargo Racks | Kargo Master
Thule Pro DeWalt Pick Up Rack System Compact - DCATR375 - Thule
Bruce
   / Canoe #10
I use the pads on my lumber rack, got them at Dunhams Sports or some place like that.
ExMark Quest Zero Turn Mower (A50860)
ExMark Quest Zero...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A50322)
2017 Bomag BW90...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2025 K0608 UNUSED 3-Rail Style Fence Panels (A50860)
2025 K0608 UNUSED...
1267 (A50490)
1267 (A50490)
