Can my tractor pull this plow?
   / Can my tractor pull this plow? #1
Elkins45
KY
Kubota L3800
Do you think it would be reasonable to ask my Kubota L2350 (25HP 4WD) to pull this plow or one like it?
http://lexington.craigslist.org/grd/1906704446.html
My Dad used to pull a two bottom plow with a IH Super C gas tractor with no trouble. Can I expect similar performance from a CUT of similar HP?
   / Can my tractor pull this plow? #2
I think you have similar HP, but not similar weight. And weight is critical when transferring HP to the ground. I think pulling that plow would be a bit ambitious.
Mike
   / Can my tractor pull this plow? #3
I dont think so . Maybe in light soil.
   / Can my tractor pull this plow? #4
I have a L2250 Kubota 26 HP and have a similiar plow. As I see the word Winchester in the add, I am in Uxbridge Ont.
Craig Clayton
   / Can my tractor pull this plow? #5
I have a 24hp massey and I would say NO. Cutting through hard dirt is pretty tough on little tractors like ours
   / Can my tractor pull this plow? #6
Something like this would be appropriate. Ken Sweet
   / Can my tractor pull this plow? #7
I'm pulling a 2 bottom 12" (i think) dearborne with my 1635, and even it bogs down when the suck is a bit too much or the ground is hard. And I have a 3500lb tractor with loaded tires and loader/bucket on front (so I guess close to 4700lbs all said?)
   / Can my tractor pull this plow? #8
You won't be happy pulling that. Odds are pretty good that you will get stuck a lot. Remember that a bottom plow like that needs to be pulled pretty quick. A tractor struggling just won't cut it. The one Ken Sweet showed is more in line with your machines abilities.
   / Can my tractor pull this plow? #9
I doubt whether you would have the traction for one thing and even if you got it to hook up that's a lot of drag. I really think you would do a lot better than the old tractors that those were made for though it wouldn't be a total waste by any stretch imo.
Reason I say is I have a old Ford 2 bottom (about like that one) that came with the 8n's etc and I have no idea how they were expected to pull it must have been perfect dirt is all I can say!
For example my 1951 Massey Harris 22hp (similar tractor to 8n) would pull it about half depth and the slightest thing would stall the tractor or try to flip it backwards.
My newer tractor has 45hp diesel and 4wd and lots of gears (old tractors problem not enough gears) it pulls it fine but I doubt I could go any bigger. hth
   / Can my tractor pull this plow? #10
John Deere plow
The plow in that Craigslist picture is not a John Deere plow. It appears to be a Ford 101 Series trip plow. Ken Sweet
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
5TH WHEEL PLATE (A58216)
5TH WHEEL PLATE...
60in Forks (A56857)
60in Forks (A56857)
1763 (A58375)
1763 (A58375)
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2017 Ford F-150...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59575)
2018 INTERNATIONAL...
