Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,306
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
The jump starter has a built-in 12v battery and its own built-in battery charger. So, why wouldn't the built-in charger also charge an external battery when its all connected and plugged into the mains power?
You can test this if your car battery is below 12.5v (slightly rundown). 12.4v is a good number, that's about 20% down, and probably won't cause problems.
1) Charge up the jumpstarter, so it's "full".
2) Plug jumpstarter into the 120v wall outlet
3) Attach the jumpstarter clamps to your car battery.
4) Measure the voltage at the car battery. If it's about 1 volt higher, (13.4v) it will charge the car battery. If 0 volt higher there is no charging. If .5v higher, it is charging but durn slow.
5) Leave it hooked up and after awhile, if the car battery gets to 12.7v it's been charging (both) batteries.
It's more complicated than this actually, but to keep it simple this will tell you something. I wouldn't do the test if the subject battery is below 12.4v.
So, temporarily disconnecting the internal battery might make it suitable as a slow charger?
Much better to run the car for awhile, your car probably has an output of 90 amps, which is a serious charger. This jumpstarter, I would be quite surprised if it's charges at more than 3 amps, it's made to charge its internal battery overnite. Your car alternator will recharge a bad battery maybe 20-30 times faster than the jumpstarter. These are pretty wild guesses, but I don't think your jumpstarter will be a "suitable" charger (in comparison to the car's alternator).
