Can’t run a hydraulic top link on a Case 75c?
   / Can’t run a hydraulic top link on a Case 75c?
Great pics, but without the hydro-top link in place, I can only guess.
My guess is "Hoses fittings and couplers".
Might want to look into the positioning of those lower remotes, or put a bit of an extension on that top link cylinder .
Two things trying to occupy the same space at the same time.
Can you spin the hydro top link end for end and gain anything?
I’m about 99% sure you are correct. It comes into contact with the remote valves, not much, but I don’t think it takes much the crack that cast metal
   / Can’t run a hydraulic top link on a Case 75c? #12
Cast metal does not yield much. Even a little bit of contact will force something to give. In this case it is the mount for the remotes.
When the cylinder is in the top hole it can touch the remote valves, not much
Glad you were able to find the answer! Sure beats the frustration of having to chase an elusive problem.
2024 IR IRD25 HYD TRACK DUMPER (A51243)
2024 IR IRD25 HYD...
2017 Chevrolet Malibu (A50324)
2017 Chevrolet...
2018 Dodge Grand Caravan SXT Van (A50324)
2018 Dodge Grand...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
UNUSED FUTURE MINI EXCAVATOR HYD BREAKER (A51244)
UNUSED FUTURE MINI...
Rhino 484 (A50322)
Rhino 484 (A50322)
