Calling all TZ24DA & TZ18DA owners...
   / Calling all TZ24DA & TZ18DA owners... #61
OK Changed the filters one at a time. It was the Hydraulic filter under the belly of the tractor that was causing the issue. It was all dented up from me clearing a fence row. I figure it must have been slowing down the flow of the fluid.
   / Calling all TZ24DA & TZ18DA owners... #62
I have a TZ24 and have not had any issue other than the cracked fender. That was fixed under warranty. The Belt on the 60 Inch Belly Mower is showing "White" near the top edge. I travelled to a local dealer that had one in stock. Bought all the filter(s) etc to do the yearly maintenance. I had to leave the belt as it was $172.00. Is there another place I can get the belt? I have not been able to find any replacement on the Internet. Is there a cheaper replacement belt available?
Al
   / Calling all TZ24DA & TZ18DA owners... #63
I just posted on another link, but do you know the NH part number for the repair to your cracked fender?
   / Calling all TZ24DA & TZ18DA owners... #65
Bandit,
I have a 2005 TZ24DA with a 60" MMM, 10LA loader, and 48" tiller. Just went over 300 hrs on it. Purchased used from original owner 2 years ago and have been more than pleased so far. Only issue I have experienced is a leaking mid PTO seal I have to replace. Just enough to be annoying at this point.
   / Calling all TZ24DA & TZ18DA owners... #66
I have a 2007 TZ22DA with 60 MMM, and 50" 2 stage snow blower, with Firebird Fiberglass canopy, 54" snow / dozer blade( modified with power angle) also 2007 TC34Da W / 84 mmm, tl240 Loader, and 7' bradco Back Hoe, and 60" brush hog. Live in Apalachin NY, Have a great local NH dealer.
   / Calling all TZ24DA & TZ18DA owners... #67
I purchased a TZ24DA with the 12LA loader in 2004. Now has around 400 hours on it. Recently noticed that it is leaking engine oil. Seems to be coming from the bell housing area. Could this also be related to the frame cracking? I am away from my tractor now, but will check for frame cracks when I get the chance.
   / Calling all TZ24DA & TZ18DA owners... #68
I have a 2005 TZ22DA with the front snowblower and the 54"mmm. I am looking for the 10LA loader for it if anybody knows where I can find one. I don't need the hydraulic control as I already have for the front blower.
   / Calling all TZ24DA & TZ18DA owners... #69
Do you have a TZ24DA or a TC24DA? The TZ24 came with a 10LA loader and the TC24D/DA came with the 12LA loader.
If you have the TC24DA, I can probably help you out. If you take the plastic off the dash there is a hydraulic line that runs behind it. There are two metal lines connected via a short piece of hose with hose clamps. These clamps come lose and need to be tightened up periodically. I had my dealer do it under warranty once, I did it once a few years back, and I need to do it again since I put the tractor back together last year after I developed a leak in the hydrostatic pump.
   / Calling all TZ24DA & TZ18DA owners... #70
Hi All...would like to add myself to the list of TZ24DA owners. I bought mine a few days ago with 280hrs on it. So far I have tilled my garden( 60" tiller ) and am very impressed with the machine....looking forward to cutting some grass with it. I have 5 acres to mow. It doesn't have a fel on it but the previous owner had one on it so I better have a good look at the frame to see if there are any stress fractures.
I dented the hydraulic filter when I pulled the deck off for servicing so making a skid plate to protect it is now a priority. It has some of the usual issues guys have mentioned here like cracking under the seat support but overall for grass cutting and tilling it seems like it should handle them easily.
Gerry
flooring (A55758)
flooring (A55758)
Case SV280B (A53317)
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
Irrigation End Stop (A56469)
Irrigation End...
