C trike new project
   / C trike new project #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
as I found her. no bat.. / bad starter. hung a lawnmower bat on her and hand cranked her to load.
   / C trike new project #2
I sure would like to have those rear tires..!!
Sheet metal looks pretty decent. What's the funky thing above the PTO, where the belt pulley attaches..??
Now, if it only had Fast-Hitch... Guess we can't have everything...
Sweet little tractors..!! I have 2, and are just sooo handy for so many jobs.
   / C trike new project #3
I always loved the Farmal wheels. It was like mags before there time.
Are you planning to paint it Blue?!:laughing:
judging by the torch marks on the plate, I'd say it was blanked off by the prev owner.
soundguy
   / C trike new project #5
Nice find:thumbsup:
Farmall's are fun--I have two (1948 Cub, 1951 Super A).
i have a 66 cub, one of the first sn's after the conversion to a 12v system. she has the square nose metal, not the round one.. etc.
hope to have fun and learn alot on this C.
Already see I will be pulling the front off pedistal and all to yank the crank pulley and timing cover as soon as I get a suitable bearing seperator plate..
soundguy
   / C trike new project #7
soundguy
I'm probably heading that way on my 1948 Cub. Lapped the valves. Did the cylinder leak down test--valves seem to be OK, but still too much leakage.
Checked engine compression wet. The best I could get was 70 psi on cyl #1. The other three were between 50 and 60 psi. The book says 105-120 psi. The head gasket is new, but may not be sealing between cyl 2 and 3. Looks like either a DIY ring job or, maybe, just pull the engine and ship it to the machine shop for a professional job.
Like I said--old Farmall's are tons of fun. ;)
I got the bearing seperator yesterday, ordered all my seals and gaskets for the engine and pto, am ordering the manuals today.. picking up some allthread to make a crank pulley - puller backing plate for a bottle jack.. will probably start taking tin off this afternoon.
soundguy
a lil progress today!
   / C trike new project #10
If I'm not mistaken, you have a "distillate" manifold on your C...does the tractor have an "extra" small fuel tank? BobG in VA
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A51694)
2014 Glasstream...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2015 MACK CHU613 DAYCAB (A53843)
2015 MACK CHU613...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51691)
2013 International...
