BX 25 Wheel Weights vs Loaded tires.
   / BX 25 Wheel Weights vs Loaded tires.
So how do you foam fill? What is the weight difference?
   / BX 25 Wheel Weights vs Loaded tires. #12
I took my wheels to AG tire shop where a vent holes was drilled into each tire and then hot medium density foam pumped in until coming out the vent.
Tires had to remain on side until cured to avoid flat spots… I picked up the next day.
My BX tires each gained about 50-60 pounds from memory but don’t hold me to that.
Easy to carry before foam and I could not lift after foam.
   / BX 25 Wheel Weights vs Loaded tires. #13
Here is a good description…
Not cheap but no regrets on my part spending the money.
   / BX 25 Wheel Weights vs Loaded tires. #14
I have to disagree with ultrarunner on the weight. I did not weight my tires before and after foam filling, but I was able to lift my BX25 rear tires in and out of the pick-up bed before having them foam filled. After being foam filled thinking I would do the same was a wasted thought. It may be the company I used added something into the tire along with the foam to increase the tire weight, I don't know and never thought to ask, but my rear tires are way over 200 lbs each now that they are foam filled. I base this estimate on comparing the weight of the tires to my 100 lb IH tractor weights.
   / BX 25 Wheel Weights vs Loaded tires. #15
There are different densities of foam used for tires.
Not sure on weight variations.
   / BX 25 Wheel Weights vs Loaded tires. #16
I have 90gals of antifreeze mix in each R4 rear tires.
35gals in each front
350lb weights in each rear wheel.
260lbs weight block up front.
I have all 3 farm tractors equipped this way & absolutely love it (y)
I even fluid filled my Kubota ZD1511 & ZD1611 Zero rear tires & added 140lbs up front to mow my steep banks & hills.
The traction is superb
Ride is way better
WIN WIN in my book.
2025 Spirit Electric Scooter (A55853)
2025 Spirit...
Heavy Duty Wheel Balancer Machine (A55852)
Heavy Duty Wheel...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
