BX 24 Steering Cylinder leak
   / BX 24 Steering Cylinder leak #1
sngleshot
Volant, PA
Kubota BX 24 HST
I only have 125 hours on this 2008 BX 24, MMM, FEL, BH. So, it is like brand new almost (except for the mud! :D). I now have a leak in my steering cylinder. Hyd fluid leaks out pretty good where the piston rod enters the cylinder when it is being used under pressure. I am assuming the seals are bad. I have ordered a replacement seal kit from Messicks for $28 plus tax and shipping, probably around $50 when all said and done. Local hydraulics shop here will do the rebuild once I have it removed.
It doesn't look like too hard of a job to remove the cylinder but I was wondering how to keep from losing too much Hydraulic fluid when I take the hoses off? Should I plug the lines or is this something I don't have to worry too much about?
Also, once the cylinder is free, what is a good way to get the ball joints to release easily? Any special tricks or anything I should know or be watching out for? I am NOT a mechanical wizard but not bad with a wrench either. Just not enough experience I guess.
What would cause something like this to happen? Not letting it warm up first? Not being used enough? (tractor was 3 years old and had only 81 hours on it when I purchased it). Thanks in advance for any replies.
   / BX 24 Steering Cylinder leak #2
I've had the same problem with my bx, only my seal kit cost $74.00. As far as the hoses go just tie some clean rags around the hose ends to keep dirt out and release all pressure in the lines before you remove the hoses. The tie rod ends are just a coder pin and a nut,easy done.
2017 BOBCAT T595 SKID STEER (A52709)
2017 BOBCAT T595...
2020 Chevy Silverado (A56438)
2020 Chevy...
2263 (A58376)
2263 (A58376)
Giyi Excavator 44" Rake (A57149)
Giyi Excavator 44"...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
